ASUS BW-16D1X-U - Flashable?
carlsefni
Re: ASUS BW-16D1X-U - Flashable?
#151 Post by carlsefni » Wed Sep 24, 2025 2:53 am
HI!
The usual questions ... I have an ASUS BW-16D1X-U, with the following MakeMKV info:
OS device name: /dev/rdisk22
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: KLIM8IJ2503
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 81
Based on similar info that others have posted, I am guessing that this is an LG drive, and I am guessing that it is flashable with the ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin firmware. I'm using a Mac, so perhaps there is no autoflash kit available, but I should then follow the command-line process as explained in the "Ultimate UHD Drives Flashing Guide Updated 2025"?
zittrig
#152 Post by zittrig » Wed Sep 24, 2025 5:21 am
Yes, follow the guide. You can use the ASUS 3.10MK or, without sleep bug and better performance with 3-layer discs, the LG WH16NS60 1.02MK.
carlsefni
#153 Post by carlsefni » Wed Sep 24, 2025 1:35 pm
Sounds good. However, I notice that the "all you need" firmware pack I downloaded (from the "ultimate guide" page) doesn't have something obviously corresponding precisely to "LG WH16NS60 1.02MK", though it does have the sort-of-similar file "HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin". Is "HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin" indeed appropriate for my drive? I have gotten the sense from reading through other forum posts that there may be multiple firmware packs. Should I instead look for a different firmware pack with a different .bin file? (And, if so, where should I look for it?)
Also, I notice that the "ultimate guide" instructions state "the latest working version is 1.17.7 of makemkv for flashing do not use an newer version for flashing until further notice on linux". I'm not on Linux; I'm on a Mac; but should I try to first downgrade to makemkv 1.17.7 first anyway? I'm not sure if "on linux" is intended to really be a Linux-specific warning or in fact generic for all command-line flashing? Perhaps backing up to 1.17.7 would be safest in any case ...?
carlsefni
#154 Post by carlsefni » Wed Sep 24, 2025 1:55 pm
carlsefni wrote: Wed Sep 24, 2025 1:35 pm Also, I notice that the "ultimate guide" instructions state "the latest working version is 1.17.7 of makemkv for flashing do not use an newer version for flashing until further notice on linux". I'm not on Linux; I'm on a Mac; but should I try to first downgrade to makemkv 1.17.7 first anyway? I'm not sure if "on linux" is intended to really be a Linux-specific warning or in fact generic for all command-line flashing? Perhaps backing up to 1.17.7 would be safest in any case ...?
Actually, I went ahead and tried downgrading to makemkv 1.17.7, but (after getting through all the macOS security shenanigans) when I tried to launch it, I simply got the message "Fatal error occurred, program will now exit." :roll: So I either need to be able to flash with command-line tools using a more recent version of makemkv, or I guess give up on the process for the moment (or until one can do command-line flashing with more recent versions of makemkv).
#155 Post by Coopervid » Wed Sep 24, 2025 2:21 pm
carlsefni wrote: Wed Sep 24, 2025 1:35 pm Sounds good. However, I notice that the "all you need" firmware pack I downloaded (from the "ultimate guide" page) doesn't have something obviously corresponding precisely to "LG WH16NS60 1.02MK", though it does have the sort-of-similar file "HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin". Is "HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin" indeed appropriate for my drive? I have gotten the sense from reading through other forum posts that there may be multiple firmware packs. Should I instead look for a different firmware pack with a different .bin file? (And, if so, where should I look for it?)
1) This is the right firmware.
2) Issue applies to Linux only, not Mac
carlsefni
#156 Post by carlsefni » Wed Sep 24, 2025 3:38 pm
Coopervid wrote: Wed Sep 24, 2025 2:21 pm
carlsefni wrote: Wed Sep 24, 2025 1:35 pm Is "HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin" indeed appropriate for my drive? [...]
[T]he "ultimate guide" instructions state "the latest working version is 1.17.7 of makemkv for flashing do not use an newer version for flashing until further notice on linux" .... I'm not sure if "on linux" is intended to really be a Linux-specific warning or in fact generic for all command-line flashing?
Excellent -- thanks for the replies. I'll give it a go ....
carlsefni
#157 Post by carlsefni » Wed Sep 24, 2025 3:53 pm
Hmm, although the command-line flashing process seems to have concluded successfully (according ot the output), makemkv still seems unable to load a 4K UHD disc when inserted into the drive, and the drive information itself seems unchanged.
Here's the result of the command-line flashing process:
Reading input file /tmp/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: ASUS_BW-16D1X-U_A105_212012021114_KLIM8IJ2503
yes
 100% Operation finished
Done successfully
But here's the makemkv drive info, which seems exactly as before the flashing process:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
And, as noted, 4K UHD disk on not read, but just ejected, upon insertion (though at least plain old Blu-ray discs are still read).
Any ideas about what may have gone wrong or what I may have missed?
#158 Post by MartyMcNuts » Wed Sep 24, 2025 9:59 pm
carlsefni wrote: Wed Sep 24, 2025 3:53 pm Hmm, although the command-line flashing process seems to have concluded successfully (according ot the output), makemkv still seems unable to load a 4K UHD disc when inserted into the drive, and the drive information itself seems unchanged.
yes
Done successfully
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
You didn't provide the command line used but I assume you are missing 'enc'
carlsefni
#159 Post by carlsefni » Thu Sep 25, 2025 1:18 am
MartyMcNuts wrote: Wed Sep 24, 2025 9:59 pm You didn't provide the command line used but I assume you are missing 'enc'
Ah, you assume correctly. :oops: I hadn't realized that my firmware was on the encrypted list, though I really should have guessed that when it didn't seem to work! I ran it again using the format for encrypted firmware provided in the "ultimate guide" (including 'enc'), and now it all works.
Brilliant. Thanks for the help! :D
Buck Turgidson
#160 Post by Buck Turgidson » Fri Oct 03, 2025 2:40 am
Whats up fellas new to all this.
Looking to pick this up and rip my UHD collection. Is it a good option in terms of speed and ability to read discs with different amounts of layers?
xflipx
#161 Post by xflipx » Sat Oct 11, 2025 3:12 am
Billycar11 wrote: Sun Aug 10, 2025 3:40 am
niddrym wrote: Sun Aug 10, 2025 12:56 am Hi,
I have the following drive, is it flashable via another method since its not an MT1959?
OS device name:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: ...
Firmware date: 2017-12-21
Highest AACS version: 77
Drive platform: RS8601
Firmware version: E111/ID76
Mutato wrote: Sun Jun 01, 2025 12:42 pm Hi, I bought an ASUS BW-16D1H-U PRO, how can I flash it to UHD drive?
Previously I flashed my LG BH16NS40 (NS50) using cmd commands but this drive has problems with reading 3 layer discs. Sometimes it reads them sometimes throws errors "L-EC UNCORRECTABLE ERROR" and sometimes it doesn't work at all (making a strange sound).
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 78
Drive platform: RS8F00
Firmware version: E116/ID71
Thanks for your help
yes just email me that info see below for email i have an auto flasher for you
Hey Billy I sent an email to ya, but could I get the FW files as well?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL125184WL
Highest AACS version: 82
#162 Post by Coopervid » Sat Oct 11, 2025 10:13 am
xflipx wrote: Sat Oct 11, 2025 3:12 am
OS device name:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: ...
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
You omitted to post the most important part "Drive platform". If it's MT1959 you have an LG and you can flash it yourself.
OB11BO
#163 Post by OB11BO » Fri Oct 17, 2025 3:57 pm
Just picked up one of these with the info below. Can I please get instructions for flashing? Thank you!
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL127360WL
Firmware version: ID76
#164 Post by Coopervid » Fri Oct 17, 2025 4:34 pm
OB11BO wrote: Fri Oct 17, 2025 3:57 pm Just picked up one of these with the info below. Can I please get instructions for flashing? Thank you!
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
PM is coming.
OB11BO
#165 Post by OB11BO » Fri Oct 17, 2025 6:49 pm
Coopervid wrote: Fri Oct 17, 2025 4:34 pm
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
PM is coming.
