Longshot with Pioneer BDR-209D
saegezauberer
Re: Longshot with Pioneer BDR-209D
Worked instantly. Donation sent. Thanks a lot!
magicqueen
can someone please help me out with getting my BDR-209D to UHD?
It seems someone here had the same firmware as I have.
OS device name: I:
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.20
Serial number:
Firmware date: 2014-04-08
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.20/ID61
OS device name: I:
Revision: 1.20
Serial number:
PM sent.magicqueen wrote: Sun Nov 02, 2025 5:48 pm Hi,
OS device name: I:
Revision: 1.20
Serial number:
bauercole
Any chance I'd be able to flash my drive?
OS device name: /dev/sr0
Revision: 1.34
Serial number:
Firmware date: 2016-04-25
Firmware version: 1.34/ID61
Revision: 1.34
Serial number:
PM sent.bauercole wrote: Thu Nov 06, 2025 7:08 pm Any chance I'd be able to flash my drive?
Revision: 1.34
Serial number:
TThor45
ive got the same drive only (FW1.51) any help?
Post your Makemkv info.
cse1024
Could you please assist with flashing my drive?
OS device name: Q:
Revision: 1.20
Serial number:
Highest AACS version: 27
PM sent.cse1024 wrote: Sun Nov 16, 2025 10:59 am Could you please assist with flashing my drive?
Drive Information OS device name: Q: Manufacturer: PIONEER Product: BD-RW BDR-209D Revision: 1.20 Serial number: Firmware date: 2014-04-08 Bus encryption flags: 13 Highest AACS version: 27 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.20/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
cse1024
Thank you so much! Donation sent.
HUMBY
Hi All
If i could just jump on the band wagon here could anyone tell me if my drive is flashable to read UHD disks?
Revision: 1.20
Serial number: NGDL056633WL
Highest AACS version: 39
If so would it be possible to send me the software to flash it?
Thanks so much
Nick
Revision: 1.20
Thanks so much
Nick
norliss
Hey, I've had a BDR-209D and assumed it would be too old to be suitable for ripping UHD discs but perhaps I was mistaken? Here's the details from mine:
Product: BD-RW BDR-209M
Revision: 1.33
Serial number: **************
Firmware date: 2015-12-09
Highest AACS version: 76
Firmware version: 1.33/ID60
PM sent.HUMBY wrote: Fri Nov 21, 2025 8:40 pm Hi All
Revision: 1.20
Thanks so much
Nick
PM sent.norliss wrote: Sat Nov 22, 2025 10:48 am Hey, I've had a BDR-209D and assumed it would be too old to be suitable for ripping UHD discs but perhaps I was mistaken? Here's the details from mine:
Revision: 1.33
movo01
Hey, this is my first post in this forum. I recently got a UHD disc and wondered if it is possible to rip it with my BDR-209D? Is it possible to do this from linux? My details:
Revision: 1.34
Serial number:
Highest AACS version: 62
