Dump Submitted: MKB20_v77_28_Years_Later_63FC.tgz
csbond2
Post by csbond2 »
It was submitted to support. I'm not sure if that's where it was supposed to go or not but what I read that was my guess. And it has a different key from the other submission.
BizzyB
Re: Dump Submitted: MKB20_v77_28_Years_Later_63FC.tgz
Post by BizzyB »
csbond2 wrote: Tue Sep 23, 2025 5:07 pm MKB20_v77_28_Years_Later_63FC.tgz
Did you submit to svq@makemkv.com?
hanakuin
Post by hanakuin »
I submitted MKB20_v77_28_Years_Later_13A6.tgz to svq@makemkv.com
csbond2
Post by csbond2 »
BizzyB wrote: Tue Sep 23, 2025 8:40 pm
Yes i sent it there.
oatmeal769
Post by oatmeal769 »
How do we check if it works, or has been validated (not sure the terminology)? I have the exact same dump.
oatmeal769 wrote: Thu Sep 25, 2025 10:51 pm How do we check if it works, or has been validated (not sure the terminology)? I have the exact same dump.
For MakeMKV:
Simply try to rip the disc again. You may also notice in the log window when MakeMKV downloads the latest HK.
For KeyDB:
You can download the latest KeyDB file and search for you discID (SHA-1 of the Unit_Key_RO.inf file on the disc or in the dump). If a record exists and it contains the VUK (| V |) then you are good to go!
oatmeal769
MartyMcNuts wrote: Thu Sep 25, 2025 11:14 pm Simply try to rip the disc again. You may also notice in the log window when MakeMKV downloads the latest HK.
This led me to realize there's a new update to the MakeMKV software. Downloaded, and good to go! THANKS!
