Asus BW-16D1X-U
ajohnson6494
Re: Asus BW-16D1X-U
#256 Post by ajohnson6494 » Fri Sep 12, 2025 9:36 pm
Is the following drive able to be flashed for UHD discs, if so where can I find the flasher for this drive? Thanks in advance!
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Firmware date: 2020-07-21
Highest AACS version: 75
Firmware version: ID76
Re: Asus BW-16D1X-U
#257 Post by Billycar11 » Sat Sep 13, 2025 12:27 am
ajohnson6494 wrote: Fri Sep 12, 2025 9:36 pm Is the following drive able to be flashed for UHD discs, if so where can I find the flasher for this drive? Thanks in advance!
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
yea email me see below
jase52476
Re: Asus BW-16D1X-U
#258 Post by jase52476 » Mon Sep 15, 2025 4:16 am
I'm getting ready to try to flash my drive, and here is the details from MakeMKV:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: [REDACTED]
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 81
I've read all the posts here : viewtopic.php?f=4&t=23129
I've read the guide here: viewtopic.php?f=16&t=19634
Along with all the posts in this topic.
I saw several posts with people with my exact same drive, same revision number, etc. using 2 different firmwares:
1) BW-16D1HT : ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
2) WH16NS60 : HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
I saw one person mention this one and confirmed it worked, but the previous two seem to be the ones everyone had used:
3) BW-16D1H-U : ASUS-BW-16D1H-U-A204-WM01001-211901041044.bin
I have downloaded the firmware pack : mk-firmware-pack-20200720.zip, and I have located the sdf_00000097.bin from the following location:
/Applications/MakeMKV.app/Contents/Resources/appdata.tar
tar -tvf appdata.tar -> shows bin file was sdf_00000097.bin
# Extract bin file:
tar -xvf appdata.tar sdf_00000097.bin
I then go into this folder : /Applications/MakeMKV.app/Contents/MacOS
There are two executables there that I have seen mentioned (in addition to others): makemkvcon & sdftool.
I did this command:
./sdftool -l
Found 1 drives(s)
00: /IOBDServices/D0D89CEE
  ASUS_BW-16D1X-U_A105_212012021114_[REDACTED]
# I wanted to dump the current firmware in case I need to revert it:
./sdftool -d /IOBDServices/D0D89CEE dump -o ~/Downloads/
# One file was created:
dump_user_ASUS_BW-16D1X-U_A105_212012021114_[REDACTED].tar
# Contents of the tar:
 % tar -tvf ~/Downloads/dump_user_ASUS_BW-16D1X-U_A105_212012021114_[REDACTED].tar
-rw-r--r--  0 0      0          32 Dec 31  1969 rom_003000.bin
-rw-r--r--  0 0      0         256 Dec 31  1969 rom_1EC000.bin
-rw-r--r--  0 0      0       65536 Dec 31  1969 rom_1F0000.bin
-rw-r--r--  0 0      0          96 Dec 31  1969 inq.bin
-rw-r--r--  0 0      0          28 Dec 31  1969 fd_fwdate.bin
-rw-r--r--  0 0      0          28 Dec 31  1969 fd_sn.bin
My question is, should I be using makemkvcon or sdftool?
I saw several people using makemkvcon, but then I saw others using sdftool almost interchangeably .
It appears as though I could just do this:
./sdftool -d /IOBDServices/D0D89CE  rawflash -i ~/Downloads/mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Or use the makemkvcon tool:
# My drive says my Bus Encryption Flags: 1F, so I'm assuming mine is encrypted and I need main,enc on the command?
./makemkvcon -d /IOBDServices/D0D89CE -f ~/Downloads/sdf_00000097.bin  rawflash main,enc -i ~/Downloads/mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
It seems some use the sdf.bin or sdf_#########.bin and some don't. I'm just wondering what is the current way to do this?
I just want to understand what the difference between sdftool and makemkvcon is and what the sdf_00000097.bin is for, etc.
Thanks in advance.
fio1982
Re: Asus BW-16D1X-U
#259 Post by fio1982 » Tue Sep 23, 2025 4:37 pm
Please i need help with mine if someone can help me:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 76
Re: Asus BW-16D1X-U
#260 Post by Coopervid » Tue Sep 23, 2025 7:51 pm
fio1982 wrote: Tue Sep 23, 2025 4:37 pm Please i need help with mine if someone can help me:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
Shmuel2025
Re: Asus BW-16D1X-U
#261 Post by Shmuel2025 » Wed Sep 24, 2025 4:37 am
Current profile: CD-ROM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 63
could some one please help me flash this drive
Re: Asus BW-16D1X-U
#262 Post by Coopervid » Wed Sep 24, 2025 2:29 pm
Shmuel2025 wrote: Wed Sep 24, 2025 4:37 am
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
happyb
Re: Asus BW-16D1X-U
#263 Post by happyb » Sun Sep 28, 2025 6:46 pm
Hi all, I'm new to this and was wondering if an Asus with the Pioneer RS8F00 would be second best to getting an actual Pioneer since they are so hard to find? I downloaded MakeMKV on my friends computer and his ASUS shows as a Pioneer. Should I buy it from him and flash it? Thanks
Re: Asus BW-16D1X-U
#264 Post by Coopervid » Sun Sep 28, 2025 8:32 pm
happyb wrote: Sun Sep 28, 2025 6:46 pm Hi all, I'm new to this and was wondering if an Asus with the Pioneer RS8F00 would be second best to getting an actual Pioneer since they are so hard to find? I downloaded MakeMKV on my friends computer and his ASUS shows as a Pioneer. Should I buy it from him and flash it? Thanks
The hardware is a Pioneer drive. Get it and post its Makemkv info to get it flashed.
happyb
Re: Asus BW-16D1X-U
#265 Post by happyb » Tue Sep 30, 2025 1:32 am
Coopervid wrote: Sun Sep 28, 2025 8:32 pm
Thank you, I got it and here is the info.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 16
Re: Asus BW-16D1X-U
#266 Post by Coopervid » Tue Sep 30, 2025 8:31 am
happyb wrote: Tue Sep 30, 2025 1:32 am
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
Buck Turgidson
Re: Asus BW-16D1X-U
#267 Post by Buck Turgidson » Sun Oct 12, 2025 1:14 am
Hey guys,
This is the follwing info on my drive and im using an Apple MacBook M3 Pro on Tahoe 26.1
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Let me know if you need any other info
Re: Asus BW-16D1X-U
#268 Post by Coopervid » Mon Oct 13, 2025 11:08 am
Buck Turgidson wrote: Sun Oct 12, 2025 1:14 am Hey guys,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent. You need a good VM to run Windows.
TingOnTing
Re: Asus BW-16D1X-U
#269 Post by TingOnTing » Thu Oct 16, 2025 9:27 am
I also have
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 65
Is this possible to be flashed for UHD i am getting mixed messages
Re: Asus BW-16D1X-U
#270 Post by Billycar11 » Thu Oct 16, 2025 3:52 pm
TingOnTing wrote: Thu Oct 16, 2025 9:27 am I also have
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Yes email me that drive info section see below for email
