LibreDrive for Pioneer drives
NotJoseph
#1636 Post by NotJoseph » Fri Sep 12, 2025 12:21 pm
I guess my questions are: is it UHD capable for $25 and/or is it libredrive capable for not $25? I'm just confused trying to read the 1500+ posts and not making sense of it.
#1637 Post by Billycar11 » Fri Sep 12, 2025 6:30 pm
NotJoseph wrote: Fri Sep 12, 2025 12:21 pm I guess my questions are: is it UHD capable for $25 and/or is it libredrive capable for not $25? I'm just confused trying to read the 1500+ posts and not making sense of it.
It will be released for free eventually but for now it's not public
slagathor
#1638 Post by slagathor » Wed Sep 17, 2025 3:55 am
@billycar11 I bought a Pioneer drive from you and it was working fine a few months ago but can't use it to play or rip UHD anymore. I did not update any firmware. I'm wondering if it's because it says Firmware type: Original (unpatched) but confused because it does also say Status: Enabled under Libre Drive Information. Let me know how to proceed, thanks.
MakeMKV Info
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-S13JX
Revision: 1.03
Serial number: __________
Firmware date: 2022-07-26
Highest AACS version: 77
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.03/ID72
Disc Information
Label: DONT_LOOK_NOW
Timestamp: 2023-07-31 15:14:34
Protection: AACS2.0/C v77
Data capacity: 93.21 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
When trying to rip UHD I get:
MakeMKV v1.18.1 linux(x64-release) started
Saved AACS dump file as /home/slagathor/.MakeMKV/MKB20_v77_DON'T_LOOK_NOW_2E31.tgz
#1639 Post by Billycar11 » Wed Sep 17, 2025 5:19 am
slagathor wrote: Wed Sep 17, 2025 3:55 am @billycar11 I bought a Pioneer drive from you and it was working fine a few months ago but can't use it to play or rip UHD anymore. I did not update any firmware. I'm wondering if it's because it says Firmware type: Original (unpatched) but confused because it does also say Status: Enabled under Libre Drive Information. Let me know how to proceed, thanks.
MakeMKV Info
Revision: 1.03
Disc Information
Number of layers: 3
something has changed in your setup
either your on a new pc with no access to hk downloads
or your docker does not pass through libredrive commands
slagathor
#1640 Post by slagathor » Thu Sep 18, 2025 10:56 pm
@billycar11 I did switch to Linux from Windows. Does the Linux version of MakeMKV not have access to HK downloads? I'd prefer not to have to use Windows if possible.
If it matters, I am using Arch Linux and installed according to these MakeMKV instructions. I've also tried using the AUR version of MakeMKV but get the same error regardless. I can play / rip Bluray just fine btw.
Anything I can do here to get this working?
#1641 Post by Billycar11 » Thu Sep 18, 2025 11:01 pm
slagathor wrote: Thu Sep 18, 2025 10:56 pm @billycar11 I did switch to Linux from Windows. Does the Linux version of MakeMKV not have access to HK downloads? I'd prefer not to have to use Windows if possible.
You have to get your hk downloads working or make sure the docker passes through the drive fully
Both show similar issues
All that can work on Linux fine it just a matter of having it setup correctly
Atmos
#1642 Post by Atmos » Mon Sep 22, 2025 6:24 pm
Hi, first time posting.
Ive had my Pioneer 211UKB drive for years. This week I downloaded MKV fir the first time and ripped 4 movies no problem. Today I tried The Revenant but evertime it got to the end it failed. Tried 3 times.
Then disaster struck.
I googled FW and found a new version - 1.54 version. I downloaded and installed from 1.52 not realising what I was letting myself in for.
Now the drive fails to read UHDs.
I'm gutted.
Any help?
Regards.
#1643 Post by Coopervid » Mon Sep 22, 2025 9:21 pm
Atmos wrote: Mon Sep 22, 2025 6:24 pm Hi, first time posting.
I'm gutted.
Any help?
Regards.
You are f...ed and have to wait until Mike comes up with a solution. No ETA.
khm5150
#1644 Post by khm5150 » Tue Sep 23, 2025 11:38 pm
BD-RW BDR-XS07U ?
#1645 Post by MartyMcNuts » Wed Sep 24, 2025 1:31 am
khm5150 wrote: Tue Sep 23, 2025 11:38 pm BD-RW BDR-XS07U ?
What about it?
Amethyst
#1646 Post by Amethyst » Fri Sep 26, 2025 10:47 am
I just boght an asus external drive and make mkv shows the following: Drive Information
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: edited out
Firmware date: 2020-07-21
Firmware version: ID76
I cannot flash any firmware. Is this drive supported at all? I just spent like $170 on this, so would be great if it is supported but just not added.
#1647 Post by Billycar11 » Fri Sep 26, 2025 12:59 pm
Amethyst wrote: Fri Sep 26, 2025 10:47 am I just boght an asus external drive and make mkv shows the following: Drive Information
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
sure just email me that info
Amethyst
#1648 Post by Amethyst » Fri Sep 26, 2025 1:14 pm
Billycar11 wrote: Fri Sep 26, 2025 12:59 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
I just sent an email. Hope it got through.
#1649 Post by Billycar11 » Fri Sep 26, 2025 2:11 pm
Amethyst wrote: Fri Sep 26, 2025 1:14 pm I just sent an email. Hope it got through.
yup responded you should already have your flasher
Amethyst
#1650 Post by Amethyst » Fri Sep 26, 2025 5:08 pm
Yup It works perfectly! Now I can start building my jelyfin library.
