Looking for info if this drive can be flashed to a newer firmware that is UHD capable, Drive Info posted below.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S12
Revision: 1.01
Serial number: AGxxxxxx55WL
Firmware date: 2020-07-21
Highest AACS version: 16
Drive platform: RS8F00
Firmware version: 1.01/ID45
Disc Information
Label: LAW_ABIDING_CITIZEN
Timestamp: 2009-12-14 10:59:22
Protection: AACS v16
Data capacity: 34.20 Gb
Disc type: BD-ROM
Number of layers: 2
Pioneer BDR-S12XLB UHD Capable?
Re: Pioneer BDR-S12XLB UHD Capable?
PM sent.wildchild77 wrote: Sun Sep 21, 2025 6:49 pm Looking for info if this drive can be flashed to a newer firmware that is UHD capable, Drive Info posted below.
OS device name: E:
Revision: 1.01
Disc Information
Disc type: BD-ROM
Number of layers: 2
wildchild77
Worked Perfectly & ThanksCoopervid wrote: Mon Sep 22, 2025 8:41 amPM sent.wildchild77 wrote: Sun Sep 21, 2025 6:49 pm Looking for info if this drive can be flashed to a newer firmware that is UHD capable, Drive Info posted below.
OS device name: E:
Revision: 1.01
Disc Information
Disc type: BD-ROM
Number of layers: 2
Rmafive
I've got the same drive. Looking for similar info on cross flashing the S12 for UHD use.Coopervid wrote: Mon Sep 22, 2025 8:41 amPM sent.wildchild77 wrote: Sun Sep 21, 2025 6:49 pm Looking for info if this drive can be flashed to a newer firmware that is UHD capable, Drive Info posted below.
OS device name: E:
Revision: 1.01
Disc Information
Disc type: BD-ROM
Number of layers: 2
Revision: 1.01
Serial number: AKxxxxxxx52WL
Highest AACS version: 82
PM sent.Rmafive wrote: Sun Dec 07, 2025 11:26 pmI've got the same drive. Looking for similar info on cross flashing the S12 for UHD use.Coopervid wrote: Mon Sep 22, 2025 8:41 amPM sent.wildchild77 wrote: Sun Sep 21, 2025 6:49 pm Looking for info if this drive can be flashed to a newer firmware that is UHD capable, Drive Info posted below.
OS device name: E:
Revision: 1.01
Disc Information
Disc type: BD-ROM
Number of layers: 2
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-S12 Revision: 1.01 Serial number: AKxxxxxxx52WL Firmware date: 2020-07-21 Bus encryption flags: 1B Highest AACS version: 82 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: 1.01/ID45 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
