Schachma
#3151 Post by Schachma » Tue Sep 16, 2025 7:55 am
Hello everyone, I have the following drive and it works perfectly with dvds and blu-rays, but I recently got a couple of UHD titles and wanted to see if it is possible to make this one UHD capable? Thanks in advance!
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.50
Firmware date: 2017-12-21
Bus encryption flags: 13
Highest AACS version: 70
Drive platform: RS8601
Firmware version: 1.50/ID61
#3152 Post by Coopervid » Wed Sep 17, 2025 9:13 am
Schachma wrote: Tue Sep 16, 2025 7:55 am Hello everyone, I have the following drive and it works perfectly with dvds and blu-rays, but I recently got a couple of UHD titles and wanted to see if it is possible to make this one UHD capable? Thanks in advance!
Revision: 1.50
PM sent.
jsmelcer
#3153 Post by jsmelcer » Fri Sep 19, 2025 7:09 pm
A bit confused by this statement. Does this mean if i buy one of the ones that say "Currently work" it still has to be an old one with prior fw? or do the new ones work regardless
Billycar11 wrote: Mon May 27, 2019 5:20 am Pioneer UHD drives are now supported more info about that will be coming from the developer and once the info is out i will update stuff here
this is a work in progress PSA now most Pioneers come with new fw that prevents them from be crossflashed or downgraded do not buy one for UHD at this time[/u][/b]
Pioneer Drives need Firmware from before December 2022 firmware after this does not work do not update if you have a working one more on this in the coming weeks if they can be flashed. if your pioneer UHD drive does not work post your makemkv drive info here: viewtopic.php?f=19&t=27378
drives that Currently work are:
BDR-XD08UMB-S Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-XD07UHD Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-XD06JUHD Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S12UHT Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-XS07UHD Slim Slot load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-212UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-211UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-UD04 Slim 9.5mm tray load slim sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S13U-X Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S13UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
please tell me more if you have a pioneer UHD drive and it works i will add it to the list
#3154 Post by Billycar11 » Fri Sep 19, 2025 8:23 pm
jsmelcer wrote: Fri Sep 19, 2025 7:09 pm A bit confused by this statement. Does this mean if i buy one of the ones that say "Currently work" it still has to be an old one with prior fw? or do the new ones work regardless
They have to be old before 12/22 fw but this will change soon
jsmelcer
#3155 Post by jsmelcer » Fri Sep 19, 2025 9:04 pm
Billycar11 wrote: Fri Sep 19, 2025 8:23 pm
Change for the better?
#3156 Post by Billycar11 » Sat Sep 20, 2025 1:45 am
jsmelcer wrote: Fri Sep 19, 2025 9:04 pm Change for the better?
Yes Mike says all new pioneer fw will be supported
thirdeyemonkey
#3157 Post by thirdeyemonkey » Sun Sep 21, 2025 12:06 am
Hi, I've been reading through the forums and am a little confused on the state of the Pioneer drives. Is it possible to get this drive to read UHD? Thanks in advance for any help!
Revision: 1.34
Firmware date: 2016-04-25
Highest AACS version: 19
Drive platform: RS8600
Firmware version: 1.34/ID81
BuffaloSlack
#3158 Post by BuffaloSlack » Sun Sep 21, 2025 3:09 am
Just wanted to thank the OP and old and new posters alike for all the information, successfully flashed a Buffalo BRXL-PUS6U3B with HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin to enable LibreDrive functionality. Posting it here for the future Google travelers looking for current information.
Cheers everyone.
#3159 Post by Billycar11 » Sun Sep 21, 2025 6:55 am
thirdeyemonkey wrote: Sun Sep 21, 2025 12:06 am Hi, I've been reading through the forums and am a little confused on the state of the Pioneer drives. Is it possible to get this drive to read UHD? Thanks in advance for any help!
Revision: 1.34
thats a pioneer you need to email me to flash that see below for email and details
Shakalaka
#3160 Post by Shakalaka » Sun Sep 21, 2025 9:44 am
Hello all
Anyone can help me with this one?
Nom du lecteur SE : E:
Fabricant : ASUS
Produit : BW-16D1H-U
Révision : E116
Numéro de série :
Date micrologiciel : 2020-07-21
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 28
Drive platform: RS8F00
Firmware version: E116/ID71
Thanks in advance
Discman
#3161 Post by Discman » Sun Sep 21, 2025 12:06 pm
Hi! I am new to this forum and tried to find answers by digging through this thread, but somehow I am lost.
I downloaded the "All you need package" as well as "mk-firmware-pack-20200720" linked in this thread. But in neither I can find an "MK" version of the firmware I am looking for.
Product: BD-RE BU40N
Revision: 1.05
Serial number: MOFP4EG0927
Highest AACS version: 81
I flashed HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin out of the "mk-firmware-pack-20200720" package. However, LibreDrive remains "not yet enabled" (flashing completed at 100% without any errors).
Reading through this forum and asking ChatGPT, I understand I need something like "1.04MK" or better "1.03MK" which seems to be the recommended version. However, this "MK" version cannot be found in the packages ... Can anybody help?
I am using an external slim drive in case that should matter.
#3162 Post by Billycar11 » Sun Sep 21, 2025 12:30 pm
Discman wrote: Sun Sep 21, 2025 12:06 pm Hi! I am new to this forum and tried to find answers by digging through this thread, but somehow I am lost.
Revision: 1.05
add enc
Discman
#3163 Post by Discman » Sun Sep 21, 2025 3:10 pm
Billycar11 wrote: Sun Sep 21, 2025 12:30 pm add enc
Thanks, that did the trick!
I stumbled about "add enc" already while studying this thread, but I did not understand what "enc" was. I thought another piece of SW or so ... Now I used Google and now I understand.
To everybody who's in the same situation: It's a parameter that needs to be added to the flashing command.
Once again, thank you very much!
Magnetmat
#3164 Post by Magnetmat » Mon Sep 22, 2025 7:10 pm
Could you help with this, I have an Asus drive that shows up in MakeMkV with this drive information:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number:
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 57
is it possable to flash the drive dispite it being on version 3.11 and if so, how?
-Jim-
#3165 Post by -Jim- » Mon Sep 22, 2025 10:10 pm
You are where i was a few weeks ago. Yes, it's very possible, as I've done it with help from this site. :D .
Read my posts and the replies starting from here a few pages back:
viewtopic.php?p=181139#p181139
Good Luck! 8)
