problem
cloriaux
problem
Post by cloriaux »
Sorry for my english...
I did opened a file, select a title and englisk audio, and then press MAKE MKV. It took a while but after 15 minutes, the only think I can see on my deskstop (output file) is a title folder with nothing inside. No movies ! I tried with 2 different movies but nothing !
How can I fix it ? Thanks a lot
Smithcraft
Re: problem
Post by Smithcraft »
What disk? What region?
Maybe some screen caps as you go through the process would be good.
SC
