Error on Purple Rain blu-ray
want2beunique
Post by want2beunique »
This is my first time posting so please forgive any mistakes....
I'm getting the following errors when attempting to back up my Purple Rain Blu-ray disk (below). I have also attached the *-tree and *-disk text files. It is an older external Blu-ray player (connected via USB). I have no issues with many more contemporary disks to I'm thinking the issue is with this specific disk and not the player, but I could be mistaken.
The disk has been cleaned using a DVD cleaner and plays fine in VLC Player and a stand-alone Blu-ray player.
Thank you for any help you can provide!
Saving 1 titles into directory D:/Videos/Ripped
Failed to save title 1 to file D:/Videos/Ripped/Purple Rain_t01.mkv
0 titles saved, 1 failed
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '17332174848'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '17332174848'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '17332174848'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '17332174848'
Encountered 47 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
PURPLE RAIN-disc.txt
(20.13 KiB) Downloaded 210 times
Re: Error on Purple Rain blu-ray
Have you tried power cycling your drive and restarting your computer? It seems like LibreDrive or some decryption component of MakeMKV didn't load properly.
want2beunique
Yes, the computer and drive have been restarted several times. No change in the results….
Thanks for taking a look!
want2beunique wrote: Sun Sep 21, 2025 12:00 am This is my first time posting so please forgive any mistakes....
Think there might be something wrong with your disc.
want2beunique
MartyMcNuts wrote: Tue Sep 23, 2025 5:04 am Think there might be something wrong with your disc.
I don't disagree. Just hoping there might be another resolvable issue. Like I said, plays fine in VLC and Blu-Ray players. Although, I have to say, after watching it so much recently, I might be good throwing the disk out....
Thank you for taking a look.
want2beunique wrote: Thu Sep 25, 2025 2:37 am
Unless you want to try another ripping software and see if it works?
