Schachma wrote:
Tue Sep 16, 2025 7:55 am
Hello everyone, I have the following drive and it works perfectly with dvds and blu-rays, but I recently got a couple of UHD titles and wanted to see if it is possible to make this one UHD capable? Thanks in advance!
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.50
Firmware date: 2017-12-21
Bus encryption flags: 13
Highest AACS version: 70
Drive platform: RS8601
Firmware version: 1.50/ID61
PM sent.
jsmelcer
Post by jsmelcer »
A bit confused by this statement. Does this mean if i buy one of the ones that say "Currently work" it still has to be an old one with prior fw? or do the new ones work regardless
Billycar11 wrote:
Mon May 27, 2019 5:20 am
Pioneer UHD drives are now supported more info about that will be coming from the developer and once the info is out i will update stuff here
this is a work in progress PSA now most Pioneers come with new fw that prevents them from be crossflashed or downgraded do not buy one for UHD at this time[/u][/b]
Pioneer Drives need Firmware from before December 2022 firmware after this does not work do not update if you have a working one more on this in the coming weeks if they can be flashed. if your pioneer UHD drive does not work post your makemkv drive info here: viewtopic.php?f=19&t=27378
drives that Currently work are:
BDR-XD08UMB-S Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-XD07UHD Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-XD06JUHD Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S12UHT Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-XS07UHD Slim Slot load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-212UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-211UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-UD04 Slim 9.5mm tray load slim sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S13U-X Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S13UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
please tell me more if you have a pioneer UHD drive and it works i will add it to the list
jsmelcer wrote:
Fri Sep 19, 2025 7:09 pm
They have to be old before 12/22 fw but this will change soon
jsmelcer
Post by jsmelcer »
Billycar11 wrote:
Fri Sep 19, 2025 8:23 pm
Change for the better?
jsmelcer wrote:
Fri Sep 19, 2025 9:04 pm
Yes Mike says all new pioneer fw will be supported
thirdeyemonkey
Post by thirdeyemonkey »
Hi, I've been reading through the forums and am a little confused on the state of the Pioneer drives. Is it possible to get this drive to read UHD? Thanks in advance for any help!
Revision: 1.34
Firmware date: 2016-04-25
Highest AACS version: 19
Drive platform: RS8600
Firmware version: 1.34/ID81
BuffaloSlack
Post by BuffaloSlack »
Just wanted to thank the OP and old and new posters alike for all the information, successfully flashed a Buffalo BRXL-PUS6U3B with HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin to enable LibreDrive functionality. Posting it here for the future Google travelers looking for current information.
Cheers everyone.
thirdeyemonkey wrote:
Sun Sep 21, 2025 12:06 am
Revision: 1.34
thats a pioneer you need to email me to flash that see below for email and details
Shakalaka
Post by Shakalaka »
Hello all
Anyone can help me with this one?
Nom du lecteur SE : E:
Fabricant : ASUS
Produit : BW-16D1H-U
Révision : E116
Numéro de série :
Date micrologiciel : 2020-07-21
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 28
Drive platform: RS8F00
Firmware version: E116/ID71
Thanks in advance
Discman
Post by Discman »
Hi! I am new to this forum and tried to find answers by digging through this thread, but somehow I am lost.
I downloaded the "All you need package" as well as "mk-firmware-pack-20200720" linked in this thread. But in neither I can find an "MK" version of the firmware I am looking for.
Product: BD-RE BU40N
Revision: 1.05
Serial number: MOFP4EG0927
Highest AACS version: 81
I flashed HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin out of the "mk-firmware-pack-20200720" package. However, LibreDrive remains "not yet enabled" (flashing completed at 100% without any errors).
Reading through this forum and asking ChatGPT, I understand I need something like "1.04MK" or better "1.03MK" which seems to be the recommended version. However, this "MK" version cannot be found in the packages ... Can anybody help?
I am using an external slim drive in case that should matter.
Discman wrote:
Sun Sep 21, 2025 12:06 pm
Revision: 1.05
add enc
Discman
Post by Discman »
Billycar11 wrote:
Sun Sep 21, 2025 12:30 pm
add enc
Thanks, that did the trick!
I stumbled about "add enc" already while studying this thread, but I did not understand what "enc" was. I thought another piece of SW or so ... Now I used Google and now I understand.
To everybody who's in the same situation: It's a parameter that needs to be added to the flashing command.
Once again, thank you very much!
Magnetmat
Post by Magnetmat »
Could you help with this, I have an Asus drive that shows up in MakeMkV with this drive information:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number:
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 57
is it possable to flash the drive dispite it being on version 3.11 and if so, how?
-Jim-
Post by -Jim- »
You are where i was a few weeks ago. Yes, it's very possible, as I've done it with help from this site. :D .
Read my posts and the replies starting from here a few pages back:
viewtopic.php?p=181139#p181139
Good Luck! 8)
Ernesto13
Post by Ernesto13 »
Hi,Could you help with this, I have an BU40N drive that shows up in MakeMkV with this drive information:
OS device name: E:
Revision: PA05
Serial number:
Firmware date: 2120-06-11
Highest AACS version: 62
is it possable to flash the drive?
I'm trying to flash the unit and I get error code 0x82052400.
