dfechser
Re: SDFtool Flasher
Post by dfechser » Fri Sep 19, 2025 10:00 pm
I'm new to this so please be kind...
I've downloaded the SDFtool Flasher and the firmware file (I have a BP50NB40). I can see the list of encrypted firmware. How do I find out what firmware is currently on my drive in order to compare it to the list?
Thank you,
DFex
jinx100
Re: SDFtool Flasher
Post by jinx100 » Fri Sep 19, 2025 11:53 pm
When you launch MakeMKV itself, it will show your optical drive model, its firmware version and date. That and the SDFtool Flasher [url]viewtopic.php?f=16&t=22896[/url ] first post will tell you how to flash your drive. Note that your BP50NB40 if SVC: NB52 (a tag on the bottom of the drive) takes a two step process to make it UHD capable.
OneBadTexican
Re: SDFtool Flasher
Post by OneBadTexican » Sat Sep 20, 2025 4:37 am
I am trying to use the Flasher to enable my LG-WH16NS40 but I get an error message telling me I can't flash this drive. Can someone help me understand what I can do or if there is a fix? This is a brand new, never used drive.
OS device name: H:
Product: BD-RE WH16NS40
Revision: 1.01
Serial number: K97DAOE3913
Firmware date: 2113-12-06 16:58
Highest AACS version: 76
Drive platform: MT1939
Firmware version: 1.01
BD raw metadata read: Partial
Re: SDFtool Flasher
Post by dcoke22 » Sat Sep 20, 2025 6:15 am
OneBadTexican wrote: Sat Sep 20, 2025 4:37 am I am trying to use the Flasher to enable my LG-WH16NS40 but I get an error message telling me I can't flash this drive. Can someone help me understand what I can do or if there is a fix? This is a brand new, never used drive.
OS device name: H:
Revision: 1.01
Near the top of the Ultimate UHD Drives Flashing Guide there's a section that starts with "Stop Read Before Flashing". Item 2 on that list is Drive Platform MT1959. Your drive says it is drive platform MT1939. That's an older drive platform that does not support UHD. The SDFtool is saving you from flashing the wrong firmware onto the drive and rendering it unusable.
The drive you have maybe be new and unused, but it is not modern. If you can, return it.
Re: SDFtool Flasher
Post by MartyMcNuts » Sat Sep 20, 2025 8:06 am
OS device name: H:
Revision: 1.01
As dcoke22 said, it might be new but it is an old drive with the old MT1939 drive platform. The firmware on it is from 2013 so at least 12 years old!!
Can you type here what the label on top of the drive says? Or attach a pic of the label?
Re: SDFtool Flasher
Post by Billycar11 » Sat Sep 20, 2025 11:58 am
OS device name: H:
Revision: 1.01
that drive is not new man i been seeing this more and more with lg and pioneer they are re casing them in china with new build dates and selling used drives as new
AndyTrekker
Re: SDFtool Flasher
Post by AndyTrekker » Sat Sep 20, 2025 1:49 pm
Hey, I just wanted to clarify (I don't want to read through 90+ pages of replies, sorry). I just bought the ASUS drive to replace my failing LG 14-40 (purchased and flashed back in 2019?). The pinned post says "If your desktop drive has encrypted firmware, flash WH16NS60 1.02-MK first, then you can either leave it as is or flash any other desktop drive firmware if you want to." Does that mean I need to crossflash the LG firmware first, then flash on the MK 3.10 for ASUS? If so, do I use the recovery tool? Or am I good to just flash the MK 3.10?
Thanks in advance for clarifying.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number:
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 81
zittrig
Re: SDFtool Flasher
Post by zittrig » Sat Sep 20, 2025 6:44 pm
AndyTrekker wrote: Sat Sep 20, 2025 1:49 pm Hey, I just wanted to clarify (I don't want to read through 90+ pages of replies, sorry). I just bought the ASUS drive to replace my failing LG 14-40 (purchased and flashed back in 2019?). The pinned post says "If your desktop drive has encrypted firmware, flash WH16NS60 1.02-MK first, then you can either leave it as is or flash any other desktop drive firmware if you want to." Does that mean I need to crossflash the LG firmware first, then flash on the MK 3.10 for ASUS? If so, do I use the recovery tool? Or am I good to just flash the MK 3.10?
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number:
The Ultimate Flashing Guide helps here -----> viewtopic.php?f=16&t=19634
Flash directly to 3.10MK. But the firmware WH16NS60 1.02MK is the firmware I would use for this drive. Here also: direct flash.
The flasher should check the "enc" check box automatically.
AndyTrekker
Re: SDFtool Flasher
Post by AndyTrekker » Sat Sep 20, 2025 7:47 pm
zittrig wrote: Sat Sep 20, 2025 6:44 pm
Thanks! Appreciate it!
OneBadTexican
Re: SDFtool Flasher
Post by OneBadTexican » Sun Sep 21, 2025 2:47 am
Thank you Billy. Sadly, I believe you are right. I have contacted the vendor and they will send me a refund. He acknowledged that this is an older model and that his supplier sent this drive without notifying his company. He offered to upgrade the firmware to the latest 1.05 but I chose to just get a refund and buy a new one directly on Amazon even though it will be much more expensive.
I appreciate you clearing this up for me.
Thank you!
Juan
Billycar11 wrote: Sat Sep 20, 2025 11:58 am
OS device name: H:
Revision: 1.01
MrCampop
Re: SDFtool Flasher
Post by MrCampop » Mon Sep 22, 2025 7:48 pm
so i am trying to flash my drive using sdftool flasher and everytime i try to press start it does nothing. it just keeps saying ready. please help.
bub_b_les
Re: SDFtool Flasher
Post by bub_b_les » Mon Sep 22, 2025 9:45 pm
MrCampop wrote: Mon Sep 22, 2025 7:48 pm Hi,
Same
Re: SDFtool Flasher
Post by MartyMcNuts » Mon Sep 22, 2025 11:13 pm
Ensure you have MakeMKV installed in the default location.
Ensure you are using 64 bit Windows 10 /11.
Post the MakeMKV drive info / libredrive info sections for your drive.
ezulllllll
Re: SDFtool Flasher
Post by ezulllllll » Mon Sep 29, 2025 10:42 pm
Hi, I have purchased a new drive (archgon Premium Aluminum External drive) and I am trying to flash it using the tool. I have MakeMKV installed in the default location, I am using Windows 11 64bit, and I am using the most recent firmware package and SDFtool flasher versions available. I am having the same error as the previous users, when i press "start" it does nothing - just stays on "ready". Here's my MakeMKV drive info-
OS device name: E:
Product: BD-RE BU40N
Revision: 1.02
Serial number:
Harware support: Yes
Firmware support: No
Firmware version: 1.02
I am trying to flash it with DE_LG_BU40N_1.03_MK, but I experienced the same issue with the DE_LG_BU40N_1.00 firmware as well.
Thanks for any help!
Re: SDFtool Flasher
Post by dcoke22 » Tue Sep 30, 2025 1:30 am
ezulllllll wrote: Mon Sep 29, 2025 10:42 pm Hi, I have purchased a new drive (archgon Premium Aluminum External drive) and I am trying to flash it using the tool. I have MakeMKV installed in the default location, I am using Windows 11 64bit, and I am using the most recent firmware package and SDFtool flasher versions available. I am having the same error as the previous users, when i press "start" it does nothing - just stays on "ready". Here's my MakeMKV drive info-
OS device name: E:
Revision: 1.02
Serial number:
PSA: New Archgon UHD drives do not allow flashing
Does your drive have the controller chip mentioned in that post?
