Contagion (US) Won't Rip to MKV
NutFlush920
Re: Contagion (US) Won't Rip to MKV
Post by NutFlush920 »
No problems here at all. Ripped US bluray with no subtitles and English as the audio language. Ripped it the day it came out.
setarip_old
Post by setarip_old »
@NutFlush920
What software (and version number) and procedures did you use to rip your original Blu-ray disc and convert to .MKV?
LordSpawn
Post by LordSpawn »
setarip_old wrote:@LordSpawn
Hi!
Click on the following link:
http://www.makemkv.com/forum2/viewtopic ... =612#p1657
cool i downloaded and file there and put it where it says but didnt change anything. still says revoked
truckerCLOCK
Post by truckerCLOCK »
+1 Contagion will not work for me also, sent in dump file.
testmetest
Post by testmetest »
I also sent a dump file.
Thanks.
eNoize
Post by eNoize »
++1
Also couldn't get Contagion ripped, and got this message
"The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 52094976, attempting to work around"
Sent dump files as well.
bottman
Post by bottman »
zero hectic
Post by zero hectic »
Same here. Just sent the dump file.
-zero
thelangs
Post by thelangs »
Same error, fails on backup non-decrypted too.
panaman
Post by panaman »
has anyone gotton this to work?
i am on the 1.7.1
i even placed the downloaded svq file in my data directory but still no go...
i did send the dump file
truckerCLOCK
This disc seems to be problematic all the way around.....AnyDVD will allow it to copied but glitches and audio errors occur also. So maybe be awhile before it gets fixed
dptbones
Post by dptbones »
Also failed to encode Contagion to mkv.
DEBUG: Code 0 at SZC{"PGC`'Am8PYiY2eD:213133158
DEBUG: Code 0 at %{<&\Y:cX~;4Nz$`suTqp:213134216
Failed to save title 0 to file C:/Movies/Contagion/t00_Contagion.mkv
0 titles saved, 1 failed
Where are the dump files saved to?
brian163
Post by brian163 »
The dump file will be in your data directory (check your preferences for path).
panaman
Post by panaman »
dptbones wrote:Also failed to encode Contagion to mkv.
My error looks exactly the same as yours........
Failed to save title 0 to file C:/movie-ripping/t00_Contagion.mkv
setarip_old
I read in another forum that there are three different versions of protection schemes for "Contagion" (Reminiscent of the first Blu-ray release of "Avatar") - so please submit your "Contagion" dumps as they may differ from earlier submissions...
