moving to Linux
doobre
moving to Linux
#1 Post by doobre » Fri Sep 19, 2025 6:20 am
Hi there, I have a lifetime key for MakeMKV in win10, can I use the same key in the Linux version installed thru a the snap store?
cheers CD
EDIT
and a follow up Q. does the firmware flash used in win10 still apply when using through linux/Zorin?
Ooops
I have version 1.18.1 linux(x64-release) and the message says "Downloading latest SDF to /home/zcdadmin/.MakeMKV/
But this 'downloading' doesn't complete.
The directory does exist (size=2.1Mib) and inside is the _private_data.tar file.
Can I update to the new version even though the file 'has not completed'? Is it just a case off extracting contents of the archive?
cheers CD
flojo
Re: moving to Linux
#2 Post by flojo » Fri Sep 19, 2025 11:19 am
Seemingly the last stable binary is makemkv-bin-1.17.6.tar.gz, from https://makemkv.com/download/old/ Nearly 2 years old :-/
doobre
Re: moving to Linux
#3 Post by doobre » Sat Sep 20, 2025 6:35 am
that's weird
edit > I tried here viewtopic.php?t=224
but after I installed, accessing the drives was not possible.
Mr. Google pointed me to another site called something like "MakeMKV Unofficial PPD or PDD", when installed accessed the drives first time. But showed the message about downloading etc. Hence my earlier Q.
cheers CD
BuffaloSlack
Re: moving to Linux
#4 Post by BuffaloSlack » Sun Sep 21, 2025 3:04 am
that's weird
cheers CD
It's really easy to just compile it from source, I'd recommend that route.
Note there is a bug related to endless scanning on versions > 1.17.7 on Linux but it sounds like you have a LibreDrive enabled drive so that shouldn't be an issue I think but perhaps you're running into that bug.
