Hi there, I have a lifetime key for MakeMKV in win10, can I use the same key in the Linux version installed thru a the snap store?
cheers CD
EDIT
and a follow up Q. does the firmware flash used in win10 still apply when using through linux/Zorin?
Ooops
I have version 1.18.1 linux(x64-release) and the message says "Downloading latest SDF to /home/zcdadmin/.MakeMKV/
But this 'downloading' doesn't complete.
The directory does exist (size=2.1Mib) and inside is the _private_data.tar file.
Can I update to the new version even though the file 'has not completed'? Is it just a case off extracting contents of the archive?
cheers CD
moving to Linux
Re: moving to Linux
Seemingly the last stable binary is makemkv-bin-1.17.6.tar.gz, from https://makemkv.com/download/old/ Nearly 2 years old :-/
Re: moving to Linux
that's weird
edit > I tried here viewtopic.php?t=224
but after I installed, accessing the drives was not possible.
Mr. Google pointed me to another site called something like "MakeMKV Unofficial PPD or PDD", when installed accessed the drives first time. But showed the message about downloading etc. Hence my earlier Q.
cheers CD
cheers CD
Re: moving to Linux
It's really easy to just compile it from source, I'd recommend that route.doobre wrote: ↑Sat Sep 20, 2025 6:35 amthat's weird
cheers CD
Note there is a bug related to endless scanning on versions > 1.17.7 on Linux but it sounds like you have a LibreDrive enabled drive so that shouldn't be an issue I think but perhaps you're running into that bug.
