ASUS_BW-16D1HT question
Hi all,
So I just successfully flashed my ASUS_BW-16D1HT from 3.11 (from factory) to 3.10MK and now am curious if there is any reason to try moving to a different FW or just stay here?
Re: ASUS_BW-16D1HT question
You can stay, ripping and burning will be fine. But you'll have the sleep bug. You can avoid by flashing to WH16NS60 1.02MK. Ripping and burning will also be fine and no bug.
In addition: The WH16NS60 1.02 handles 3-layer UHDs (>66GB) better reading them in. The ASUS firmware will often make some sick noises reading them in and will sometimes also fail to do so.
hollywoostars
For years I was using an ASUS BW-16D1HT with the factory 3.10 firmware. At some point it started making the chonking noises and leaving with "no disk inserted." I assumed it was just failing until I saw this thread. It can open bluray disks but not UHD disks. So far I haven't had any luck with any of these FW options:
mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
mk-firmware-pack-20200720/MK/HL-DT-ST/WH16NS60/HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
mk-firmware-pack-20200720/MK/old/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
That last one seems like what you're recommending here but I wanted to be explicit. Is there another FW I should try or is this likely a hardware issue with newer disks with BDXL, etc?
Either way I'm waiting for news about modern Pioneer drives. Thanks all.
Try the WH16NS60 1.02MK with the HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin.
If you're not lucky you're free to test another.
Post your Makemkv info. Seems libredrive is not enabled and your drive is not flashed to MK firmware.hollywoostars wrote: ↑Sun Sep 21, 2025 8:15 pmFor years I was using an ASUS BW-16D1HT with the factory 3.10 firmware. At some point it started making the chonking noises and leaving with "no disk inserted." I assumed it was just failing until I saw this thread. It can open bluray disks but not UHD disks. So far I haven't had any luck with any of these FW options:
Oh, I'm sorry, in hurry I didn't seen some details.
Yeah, first post your drive information with MakeMKV. Your drive must have the technical platform MT1959 and not MT1939.
hollywoostars
Thanks again all. Let me know if there's any other info that would be helpful.
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number:
Bus encryption flags: 1F
Highest AACS version: 68
Firmware version: 3.10
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number:
hollywoostars
Maybe I should clarify as well that it used to be able to rip UHDs with the factory 3.10 but at some it started failing to open. I assumed it was hardware failing (and it might still be). It's still able to read regular blu-rays but maybe that's separate hardware or something. This thread gave me hope that new FW might bring new life to an old drive.
No, firmware most likely won't make any difference. Try cleaning the drive lasers.hollywoostars wrote: ↑Mon Sep 22, 2025 10:58 pmMaybe I should clarify as well that it used to be able to rip UHDs with the factory 3.10 but at some it started failing to open. I assumed it was hardware failing (and it might still be). It's still able to read regular blu-rays but maybe that's separate hardware or something. This thread gave me hope that new FW might bring new life to an old drive.
MysticHorizon7
have you ever had problem with BD-R DL discs?
I have problem in the layer changing.
Thanks.
Roberto
Thanks.
Roberto
MysticHorizon7
Just adding my configuration:
Informazioni unità
Nome dispositivo SO: E:
Produttore: ASUS
Prodotto: BW-16D1HT
Revisione: 3.02
Numero seriale:
Data firmware: 2117-11-24 14:13
Flag criptazione bus: 1F
Informazione LibreDrive
Stato: Abilitato
Piattaforma unità: MT1959
Tipo firmware: Originale (non modificato)
Versione firmware: 3.02
DVD tutte le regioni: Sì
Lettura dati BD raw: Sì
Lettura metadati BD raw: Sì
Velocità di lettura senza restrizioni: Sì
Informazioni unità
Produttore: ASUS
Prodotto: BW-16D1HT
Revisione: 3.02
Numero seriale:
Stato: Abilitato
Read what kitahoshi posted:MysticHorizon7 wrote: ↑Sun Oct 26, 2025 12:25 pmHi,
Thanks.
Roberto
https://forum.doom9.org/showthread.php?t=185539&page=19
MysticHorizon7
Thanks. I've read it, but I'm not able to find a solution for layer changing problem. Maybe I've missed something...Coopervid wrote: ↑Mon Oct 27, 2025 10:51 amRead what kitahoshi posted:MysticHorizon7 wrote: ↑Sun Oct 26, 2025 12:25 pmHi,
Thanks.
Roberto
Well, then let me explain it in a few words. Most issues occur at the layer break. With spare areas the drive reads back an unsuccessful written sector and writes it instead in the spare area. So the bad sector at the layer break is replaced by that and the layer break doesn't cause problems anymore. However, disc quality of most disc types is very bad today. And the problem increases if you have a lousy writer like LG and ASUS drives. So just try this method and most likely your burns will not fail anymore at the layer break.MysticHorizon7 wrote: ↑Mon Oct 27, 2025 1:19 pmThanks. I've read it, but I'm not able to find a solution for layer changing problem. Maybe I've missed something...Coopervid wrote: ↑Mon Oct 27, 2025 10:51 amRead what kitahoshi posted:MysticHorizon7 wrote: ↑Sun Oct 26, 2025 12:25 pmHi,
Thanks.
Roberto
