Hello, I have a Pioneer and I wonder if it can be flashed to UHD capable
drive information from MakeMKV v1.18.1
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.02
Serial number:
Firmware date: 2022-03-16
Bus encryption flags: 13
Drive platform: RS8F00
Firmware version: 1.02/ID61
please let me know if any additional information is needed
Flashing Pioneer BDR-212D
Re: Flashing Pioneer BDR-212D
PM sent.Recycler9789 wrote: Wed May 21, 2025 2:57 pm Hello, I have a Pioneer and I wonder if it can be flashed to UHD capable
Revision: 1.02
Serial number:
K92311b2p
Hello I also have this drive and would like to be able to rip uhd.please let me know what I need to update .
Bd-rw BDR-212d
Revision 1.02
Firmware date 2022-03-16
Bus encryption flags 13
Highest AACS version 75
Libre Drive Information
Status enabled
Drive platform RS8F00
Firmware type original unpatched
Firmware version 1.02/ID61
DVD all region yes
Bd raw data yes
Bd raw metadata yes
Unrestricted speed
Thank you for any help .
Bd-rw BDR-212d
Revision 1.02
Status enabled
DVD all region yes
Bd raw data yes
Bd raw metadata yes
Unrestricted speed
PM sent.K92311b2p wrote: Tue Jul 29, 2025 4:18 pm Hello I also have this drive and would like to be able to rip uhd.please let me know what I need to update .
Bd-rw BDR-212d
Revision 1.02
Status enabled
DVD all region yes
Bd raw data yes
Bd raw metadata yes
Unrestricted speed
Kendel
Revision: 1.02
Serial number: --
Highest AACS version: 77
Revision: 1.02
Serial number: --
email me that info see belowKendel wrote: Tue Aug 05, 2025 11:20 pm Hello I also have this drive and would like to be able to rip uhd.please let me know what I need to update .
Revision: 1.02
Serial number: --
Kendel
Emailed. Thanks Billy.
Kendel
Appreciate the help Billy! Your flasher worked and was simple. Rip'd one disc and on my 2nd one with the drive with no issues so far. Both these discs were unreadable (kept giving errors) by the Asus drives I already had. The Pioneer definitely seems to be more reliable at reading. It's a little slower--- but it doesn't matter if you can't read the disc.
Thanks again! Kendel
nurikabe
Hello, seems I have an old firmware on my 212T:
Is still possible to update the FW?Drive Information
OS device name: F:
Revision: 1.00
Serial number:
Firmware date: 2019-01-10
Firmware version: 1.00/ID61
PM sent.nurikabe wrote: Wed Sep 10, 2025 8:34 am Hello, seems I have an old firmware on my 212T:
OS device name: F:
Revision: 1.00
Serial number:
nurikabe
Success! Now I can read my library, actually I'm saving right now the german edition of Animal House with OG audio.
I thanked you appropriately, cheers!
DiscHead
Don't mind me piggybacking on this thread. My BDR-212T has finally arrived and it couldn't read my 4K test disc. Here's the output from MakeMKV.
OS device name: /dev/sr0
Revision: 1.02
Serial number: REDACTED
Highest AACS version: 78
Unrestricted read spead: Yes
PM sent.DiscHead wrote: Tue Sep 16, 2025 7:03 pm Don't mind me piggybacking on this thread. My BDR-212T has finally arrived and it couldn't read my 4K test disc. Here's the output from MakeMKV.
Revision: 1.02
apoph1s
I just got a new Pioneer BDR-212D drive to replace a LG that died. Finding these Pioneer drives is getting hard. I saw that the 212D can be flashed. What is the process to flash this drive?
Thanks.
Revision: 1.02
Serial number: DADL055270WL
Highest AACS version: 82
Thanks.
Revision: 1.02
