Buffalo BRXL 16u3 fw help
Eldrik
Post by Eldrik »
Okay so i bought a Buffalo BRXL-16u3
Mkv has this info when drive is active
OS device name: E:
Product: BD-RE BH16NS58
Revision: 1.03
Serial number: KL5OA8E5200
Firmware date: 2120-05-08 09:33
Bus encryption flags: 1F
Highest AACS version: 81
OS: Windows 11 pro
I have the All you need fw pack and the SDFTool, unpacked and ready.
+ The drive has been removed from the enclosure
+ SDFTool Says the Firmware is Encrypted.
I have seen some posts about this drive but none that match the *NS58. Maybe my brain skipped something in the search or I'm just missing it. I am in need of a correct fw to flash. If i could get a bit of help on a step by step on this drive. I am willing to do this and learn so i don't have to bother anyone later. I will admit, I learn better hands on then reading. On that I am willing to pay for this to be done, because I know this knowledge doesn't come free.
Those that respond Thank You in advance for your time.
Eldrik
Re: Buffalo BRXL 16u3 fw help
Post by Eldrik »
okay got brave!
SDFTool
1. Dumped the fw to storage
2. selected my drive, write, WH16ns60 1.02mk From the LG 5.25 fw HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936
3. SDFTool now reads: HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KL5OA8E5200 , NOT encrypted
Drive now Reads
Product: BD-RE WH16NS60
Revision: 1.02
Highest AACS version: 47
Firmware version: 1.02
Seems to be reading my BD that was doing hash errors.
Is there a better FW or did i get it right?
Wh16ns60 1.02 mk
Eldrik
Post by Eldrik »
Sweet Thanks!
croja2112
Post by croja2112 »
New member here. I'm ripping a 500+ title DVD collection to an ISO archive, and had ordered the same Buffalo drive. I couldn't get it to work with MakeMKV or WinXDVD Ripper Platinum. I kept getting a Region error, even though the DVDs and the player are both Region 1. I called tech support, and they couldn't help me, because it's a software issue. The player worked as a player, but I could not rip to ISO. I was about to return the drive to Amazon.
I found this post, used the SDFtool Flasher and the FW version indicated in this post, and boom! I'm ripping to ISO with the new drive. Thanks to the OP and the guru that responded with the correct FW version. It's nice to see people helping other people.
PS: I didn't need to remove the drive from the enclosure. I simply connected it with the OEM cable, and flashed it. It worked perfectly.
gsmarquis
Post by gsmarquis »
So I think I got the same drive. I ordered the buffalo drive as a replacement for an old one that bit the dust.
Here is what makemkv says is drive status:
OS device name: /dev/sr0
Revision: 1.02
Serial number: KLZK65B5845
Firmware date: 2119-02-23 09:35
Highest AACS version: 18
It will scan the disc or what it seems to do for a long period of time, then makemkv just stops and will report back nothing. Is this drive the same? makemkv should work for standard blurays correct? Does it need a flash to work with makemkv?
gsmarquis wrote: Wed Nov 05, 2025 10:46 pm So I think I got the same drive. I ordered the buffalo drive as a replacement for an old one that bit the dust.
Revision: 1.02
You need to flash it to enable libredrive and to read UHD discs. It should work for standard BD discs but you are better of flashing it to enable libredrive.
gsmarquis
Post by gsmarquis »
I will dump my existing OEM firmware, verify its there, then flash this one:
DE_LG_WH16NS60_1.02_MK.bin ?
EDIT: I performed the above flash. Now drive is immediately recognized and rips fast anything I have thrown at it. Pre-flash, makemkv would lock up on the scan start.
Thanks for the help on the thread I tagged in on.
Spinster72
Post by Spinster72 »
I also have the same drive as everyone in this thread (BH16NS58 inside a BRXL-16U3).
I flashed it to HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin from the "mk-fimware-pack-20200720", and it enabled LibreDrive.
But then I noticed everyone on the forum is using HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936 from the "The all you need firmware pack" (it's also in the old folder in the other firmware pack).
I'm wondering what the difference is between the 1.03 and 1.02 versions. If they are both MK (LibreDrive enabled), is one preferred over the other?
Shwalamazula
Post by Shwalamazula »
Spinster72 wrote: Sun Nov 23, 2025 8:36 pm I also have the same drive as everyone in this thread (BH16NS58 inside a BRXL-16U3).
I am actually curious about that myself. I just picked up this drive so that I could offload all of my non-4K ripping from my Pioneer. MKV was giving me some errors, so I flashed *WH16NS60-1.02* onto it and was super surprised to find out that not only are my errors gone, but it now reads and rips 4K just fine.
After extensive testing, we declared that v1.02 is better, which is why it is still the recommended version.
TommyBoy
Post by TommyBoy »
Eldrik wrote: Thu Sep 18, 2025 9:38 pm okay got brave!
SDFTool
Drive now Reads
Revision: 1.02
This is exactly what I did on a recent Buffalo drive. Worked perfect. Thanks to all for the tools and info.
Peabody111
Post by Peabody111 »
Can a drive be fixed if I bricked it when flashing the drive for librea?
Peabody111 wrote: Mon Sep 28, 2026 4:00 pm Can a drive be fixed if I bricked it when flashing the drive for librea?
Yes but unplug power and data until you recover
It see recovery section in guide or email me or Marty for recovery help
