Has anyone been brave (foolish) enough to update to the beta of Mac OX 26 (Tahoe) and test MakeMKV on it?
Thanks for any responses.
Mac OS 26 Beta
bradvan
Re: Mac OS 26 Beta
I installed the macOS Tahoe 26.0 Release Candidate that was released on September 9. So far everything seems to be working normally using MakeMKV 1.18.1. I have used it on only one disc that was a 4K Blu Ray, and that one saved successfully.
WAYFLIX
Re: Mac OS 26 Beta
Yup it's working just fine with the RC! Only detail I have noticed is the icon doesn't conform to the new design language.
asr101
Re: Mac OS 26 Beta
Thanks for your updates! I was too busy to set up an external boot to test it this time around.
tokyokie
Re: Mac OS 26 Beta
talasr101 wrote: Mon Aug 25, 2025 9:41 pm Has anyone been brave (foolish) enough to update to the beta of Mac OX 26 (Tahoe) and test MakeMKV on it?
I just now tried it, and neither version 18.1 nor 18.2 would load. I got some language about make mkv being downloaded from the Web and could damage my machine, yadda yadda yadda, but I couldn't bypass it as I used to be able to do. I'm going to try install an earlier version of MacOS and see whether that works. If anybody knows of any work-arounds, I'd be most appreciative to learn then,
Re: Mac OS 26 Beta
Presumably this method still works: Gatekeeper in macOS X 15 Sequoiatokyokie wrote: Tue Oct 07, 2025 7:48 am tal
AvidMarxist
Re: Mac OS 26 Beta
hi - i am running 26.1 and cannot get MakeMKV to open; I get the icon bouncing issue. When prompted for my password through GateKeeper, it won't even accept that. When trying to do the xattr command in terminal, the command completes, but MakeMKV still won't run. I have tried installing back to 1.17.0 and still have the issue. Has anyone had any luck here?
Batman&throbbin
Re: Mac OS 26 Beta
Hi you might want to raise this with Asmcom towards the end of this threadAvidMarxist wrote: Sat Nov 22, 2025 8:16 pm hi - i am running 26.1 and cannot get MakeMKV to open; I get the icon bouncing issue. When prompted for my password through GateKeeper, it won't even accept that. When trying to do the xattr command in terminal, the command completes, but MakeMKV still won't run. I have tried installing back to 1.17.0 and still have the issue. Has anyone had any luck here?
viewtopic.php?f=20&t=19387&hilit=Asmcom&start=1425
He mentions Tahoe 26.1 working OK
gablo1251
Re: Mac OS 26 Beta
I just updated to Tahoe 26.2 and now I get the message that I need to update MakeMKV to the latest version or I can register. I downloaded the latest version and installed it. It replaced the current version. Same problem. So I completely removed MakeMKV (drag to trash) and re downloaded and installed and still have the same problem. I did go to settings>privacy and security>allow app anyway... after getting malware warning from apple. So it should work, but MakeMKV is giving me the same error message. Is there something I'm doing wrong when re-installing? Do I need to take extra steps to completely remove the application before trying again?
Anybody else using Tahoe 26.2 have advice for install?
Thanks, I'm not big into researching macOS software issues and usually don't have problems figuring it out, but I thought I'd ask here first.
Re: Mac OS 26 Beta
So, according to the information, version 1.18.2 (as distributed) would expire in November of 2025; Operating it after that time (like NOW), would require the current beta key be installed in it.Revision history
MakeMKV v1.18.2 (25.9.2025)
Improved handling for discs with mastering errors
Small improvements and bugfixes
Have you done that? Or does your copy have a registered key enabled for it?
