NEED HELP w newly purchased LGWH16NS60
bllawson13
Post by bllawson13 »
I am new to this so please do not beat me up to hard this has been a lot to learn. I recently purchased a new drive for my computer (Ebay) where I found a drive that was highly preferred and reccomended, the LGWH16NS60. It was advertised as already being flashed and ready with the correct firmware. Anyways, I installed it today into my upgraded Optiplex and MakeMKV recognized the drive and I began to start my first BluRay rip with the new drive. It started to rip then began making a noise repeatedly. It eventually "locked up" and made no new progress. I switched to a different Bluray and this time it will not get passed the 1st stage of scanning the disc. This is contstantly my issue now.
Did I do something wrong? Below is the specs that are listed on the program screen. Perhaps I missed a step in installation?
OS device name: E:
Product: BD-RE WH16NS60
Revision: 1.00
Serial number: KLQP2AH1419
Firmware date: 2117-04-25 17:56
Firmware version: 1.00
Disc Information
Disc is being loaded
Thanks in advance!
Re: NEED HELP w newly purchased LGWH16NS60
bllawson13 wrote:
Tue Sep 16, 2025 11:54 pm
OS device name: E:
Revision: 1.00
Disc Information
Thanks in advance!
High chance: This drive is defective.
Low chance: The laser lens is polluted and therefore the drive has a hard time reading. To clean the laser lens you need either open the drive and clean the lens with a cotton swab and alcohol or get a CD lens cleaning disc if you don't want to open it.
My opinion: Return it.
bllawson13
Unfortunately I cannot return it. The seller doesn't accept returns (of course).
I will try cleaning it like you recommended. Thanks for the advice.
Post by d00zah »
Is the physical drive label consistent w/ MakeMKV output? Or, at least, indicate a viable candidate for (cross-)flashing?
