Rororororo
Hello @RESET_9999, could you provide more details about T1-T2-T3-T4 analysis and how it affects metadata, or point to a relevant source?
I tried googling it, quoting it with “resolve studio,” etc., and searching this topic, but I wasn't able to find anything except replacing L1, L2, L3, etc., which doesn't say much.
Thanks !
Thanks !
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Ugoos AM6B Plus
if it's a remux, it should be fine...geofox784 wrote: ↑Mon Sep 15, 2025 1:51 amMay be a dumb question, but I've done a fair amount of research and still don't 100% understand.
In the Dolby Vision Stuff google sheet I see chart "ENCODER GROUPS TO AVOID BECAUSE THEY DONT ENCODE DV FEL PROPERLY"
I have a AM6B+ so I can playback DV Profile 7. I wanted to confirm that I understand encoding correctly. If the group that created an mkv left the file as a Profile 7 release instead of baking the FEL / encoding it into Profile 8, is no encoding actually occurring when the MKV is created from the original bluray disk files? Wouldn't this be a lossless packaging of the data directly into an MKV format?
For example, if a release is titled "███.2025.2160p.UHD.BluRay.REMUX.DV.P7.HDR.ENG.TrueHD.Atmos.7.1.H265-BEN.THE.MEN", does it matter that the release group is in the "avoid" list?
Mediainfo shows "HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible"
That list is only for the encodes and that guy ben the men encodes are ridiculously bad: https://slow.pics/c/Yp0F0UWf
https://slow.pics/c/OA0pupEN?canvas-mode=fit-widthRororororo wrote: ↑Mon Sep 15, 2025 10:53 amHello @RESET_9999, could you provide more details about T1-T2-T3-T4 analysis and how it affects metadata, or point to a relevant source?
Thanks !
https://professionalsupport.dolby.com/s ... uage=en_US
The release of the recent dim movies (F1, Jurassic World Rebirth, and Superman) got me thinking... Is there any brightness (or lack of) where it would be better to watch the SDR release instead?
As my TV is not professionally calibrated, I think it's still better to go HDR in my situation, as I know the brightness will better match the artist's intent (as opposed to my SDR brightness, which is just eyeballed).
Have you found that most releases labeled "remux" are truly lossless remuxes, or do you have to watch out for releases labeled as a remux, but that are actually an encode that has been labeled as a remux that may have some small changed like changing from P7 to P8?
@RESET_9999 do you always generate new Dolby Vision metadata even for CMv2.9 retail P7 with manually done trim passing?
These movies are only dim compared to SDR if you don't watch SDR at reference level (100-150nits). At reference level, the HDR in these movies still win, see my youtube comparisons.coopzr wrote: ↑Tue Sep 16, 2025 3:24 amThe release of the recent dim movies (F1, Jurassic World Rebirth, and Superman) got me thinking... Is there any brightness (or lack of) where it would be better to watch the SDR release instead?
if the filename says remux, it's most likely a remux. P8 ones are probably hybrid with metadata taken from web source.geofox784 wrote: ↑Tue Sep 16, 2025 3:25 am> That list is only for the encodes
only the 4000nits MDL ones
Why is this?
only that causes an issue on my G5:
https://docs.google.com/spreadsheets/d/ ... 1289366200
Has anyone noticed that the scene cuts (workflow 2-1 in Dovi Scripts) for Alien from 1979 are rather strange and unusual compared to almost all other movies. The UHD is HDR10 plus and I ripped it myself from disc with makemkv. Same goes for the H265 remux you can find on the Internet. So my rip is definitely fine.
Anyone noticed the same? Theatrical Cut by the way.
LG OLED65G1RLA / Samsung HW-Q990D / Panasonic UB820 / Ugoos AM6B+ (CE with avdvplus Build)
If you're referring to the HDR10+ scene cuts, we no longer use them when generating DV. They often don't make sense, and Resolve's scene cut detection does a better job.
daffie wrote: ↑Sun Sep 21, 2025 2:45 pmHas anyone noticed that the scene cuts (workflow 2-1 in Dovi Scripts) for Alien from 1979 are rather strange and unusual compared to almost all other movies. The UHD is HDR10 plus and I ripped it myself from disc with makemkv. Same goes for the H265 remux you can find on the Internet. So my rip is definitely fine.
@RESET
Thanks. How to use Resolve's scene cut detection in your scripts?
The script defaults to using internal/external scene cuts or madvr to generate them, so you will have to remove HDR10plus(2-2) to force madvr.
You could also use 6-2 to create the scene cuts. Rename the generated RPU the same as the mkv and run 3-1
deadchip12
@RESET_9999
What do you think about the Kodi app on android tv? I just installed the app on my Sony a95l and it seems to play all the Dolby Vision 4K remuxes smoothly. Might be a good option for those that can't get the Ugoos.
I dont know, never had a Sony TV
deadchip12
Not necessarily a sony. Any android tv?
