What did you mean?
Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Micky12
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
The old Verbatim 43888 with the UD04 died in a second no one knows why.
So it it did and not does.
I was very lucky to buy this drive for only 49.99eur brandnew.
I hate my other 43899 I bought a month ago because it often hangs nearly at the layerbreak.
Flashed LG in it…. In my opinion no equal to pioneer.
So you still burn. Sigh.....Micky12 wrote: Mon Sep 15, 2025 5:05 pm The old Verbatim 43888 with the UD04 died in a second no one knows why.
Read this:
https://forum.doom9.org/showthread.php?t=185539&page=19
Micky12
Thx. Well this is a huge thread.
I’ll read it in the next days.
jkoiou
Hi looking for firmware for my burner so I can rip my 4K movies and watch on my PC that doesn't have a 4k drive (watch on my PS5 on a different tv in house):
It's a Verbatim
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ACDL380269WL
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Please and thank you
It's a Verbatim
Revision: 1.14
jkoiou
Hi. Can anyone help please?jkoiou wrote: Thu Sep 18, 2025 12:22 am Hi looking for firmware for my burner so I can rip my 4K movies and watch on my PC that doesn't have a 4k drive (watch on my PS5 on a different tv in house):
It's a Verbatim
Revision: 1.14
Please and thank you![]()
Sure email these details see below for emailjkoiou wrote: Thu Sep 18, 2025 12:22 am Hi looking for firmware for my burner so I can rip my 4K movies and watch on my PC that doesn't have a 4k drive (watch on my PS5 on a different tv in house):
It's a Verbatim
Revision: 1.14
poser
just picked up the Verbatim 43890 and would like to be able to use it with 4k discs if possible. any help would be greatly appreciated. The specs are below. TIA.....
OS device name: E:
Revision: 1.14
Serial number: -----------
Highest AACS version: 76
OS device name: E:
Revision: 1.14
sure email me for the flasherposer wrote: Sun Sep 21, 2025 2:17 am just picked up the Verbatim 43890 and would like to be able to use it with 4k discs if possible. any help would be greatly appreciated. The specs are below. TIA.....
OS device name: E:
Revision: 1.14
Micky12
Hey,
After a Little bit time I wanna say, that the old pioneer drive works like a charm.
Thank you very much. No issues at all, compared to the lg.
For 4K it only works with 4x but no errors at all.
I’ll use my new 43888 only for ripping my old DVDs.
ianson51
Hi I have the same dilemma I ordered the verbatim rebrand and it came with a 43889 firmware UD03 rev 1.14 I need tthe UD04 to rip 4kuhd where do I find this files anywhereCoopervid wrote: Fri Apr 04, 2025 10:05 amPM sent.hollish wrote: Wed Apr 02, 2025 7:46 pm Hi there @Coopervid, I feel bad joining in on the "please PM me firmware" band wagon, but I foolishly bought a 43890 thinking I could use it for UHD blu-rays, not really understanding the distinction as this is my first foray into backing up disc content. I was hoping to find a resolution on my own, but so far the only solution I have is "buy a different drive." I see you've still been helping people recently, so I hope you can find time to send me a PM as well.
Here is my Makemkv info:Thanks in advance!Code: Select all
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: ... Firmware date: 2020-06-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted![]()
PM sent.ianson51 wrote: Mon Oct 20, 2025 3:15 pmHi I have the same dilemma I ordered the verbatim rebrand and it came with a 43889 firmware UD03 rev 1.14 I need tthe UD04 to rip 4kuhd where do I find this files anywhereCoopervid wrote: Fri Apr 04, 2025 10:05 amPM sent.hollish wrote: Wed Apr 02, 2025 7:46 pm Hi there @Coopervid, I feel bad joining in on the "please PM me firmware" band wagon, but I foolishly bought a 43890 thinking I could use it for UHD blu-rays, not really understanding the distinction as this is my first foray into backing up disc content. I was hoping to find a resolution on my own, but so far the only solution I have is "buy a different drive." I see you've still been helping people recently, so I hope you can find time to send me a PM as well.
sappy
I mistakenly ordered a 43889, and I have a 43888 on the way. But I heard that it might be possible to rip UHD with an 43889 anyway? Not sure which drives are in them yet.
amhome
@CooperVid or whomever else is able to work with this drive - Thank you in advance.
I have two drives I wish to have UHD enabled for.
1:
OS device name: O:
Revision: 1.14
Serial number:
Highest AACS version: 82
OS device name: O:
Revision: 1.14
Serial number:
1:
OS device name: O:
Revision: 1.14
Serial number:
OS device name: O:
Revision: 1.14
Serial number:
PM sent.amhome wrote: Sat Nov 08, 2025 10:53 pm @CooperVid or whomever else is able to work with this drive - Thank you in advance.
1:
OS device name: O:
Revision: 1.14
Serial number:
OS device name: O:
Revision: 1.14
Serial number:
