Is this BDR-209D UHD capable?
4kCollector
#1 Post by 4kCollector » Fri Sep 12, 2025 3:27 am
Greetings! I found this drive floating around and I'm wondering if it can be flashed or whatever so it can rip UHDs...
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.51
Serial number:
Firmware date: 2018-05-08
Bus encryption flags: 13
Highest AACS version: 82
Drive platform: RS8601
Firmware version: 1.51/ID61
Any thoughts, forum friends?
4kCollector
Re: Is this BDR-209D UHD capable?
#2 Post by 4kCollector » Mon Sep 15, 2025 5:14 am
Never mind...the answer is yes, and Billycar11's flasher worked perfectly. Thank you Billy!
#3 Post by Coopervid » Mon Sep 15, 2025 9:49 am
4kCollector wrote: Fri Sep 12, 2025 3:27 am Greetings! I found this drive floating around and I'm wondering if it can be flashed or whatever so it can rip UHDs...
Revision: 1.51
Serial number:
PM sent.
