Pioneer RS8F00
xflipx
Pioneer RS8F00
Post by xflipx » Sat Sep 13, 2025 5:22 am
Hello all,
New guy here trying to flash my drive, I tried unsuccessfully after following the guide for my slim LG, so I invested in an ASUS one, but cannot flash it due to it not being MT1959 Platform. I know one of the active users has been PMing people on how to get it done.
Any tips or guides I can follow for it?:
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Firmware date: 2020-07-21
Highest AACS version: 81
Firmware version: ID76
Disc Information
Label: REVOLVER
Timestamp: 2008-01-26 11:41:30
Protection: CSS/CPPM
Data capacity: 7.63 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
jmwilt21
Re: Pioneer RS8F00
Post by jmwilt21 » Mon Sep 15, 2025 12:14 am
I purchased the same drive and would also like the solution. Thank you!
zittrig
Re: Pioneer RS8F00
Post by zittrig » Mon Sep 15, 2025 4:35 am
This one contains a Pioneer drive, not an LG-based drive. Billycar11 or CooperVid should be able to help you.
But there is a specific thread for the ASUS BW-16D1X-U ----> viewtopic.php?f=16&t=32872&p=183020#p183020
Re: Pioneer RS8F00
Post by Coopervid » Mon Sep 15, 2025 9:00 am
xflipx wrote: Sat Sep 13, 2025 5:22 am Hello all,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Disc Information
Label: REVOLVER
Disc type: DVD-ROM
Disc size: 120mm
PM sent.
Re: Pioneer RS8F00
Post by Coopervid » Mon Sep 15, 2025 9:02 am
jmwilt21 wrote: Mon Sep 15, 2025 12:14 am I purchased the same drive and would also like the solution. Thank you!
You need to post your own Makemkv info.
xflipx
Re: Pioneer RS8F00
Post by xflipx » Tue Sep 16, 2025 1:24 am
Thank you, I will be traveling this week and as soon as I get home I will give it a try!
Coopervid wrote: Mon Sep 15, 2025 9:00 am
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Disc Information
Label: REVOLVER
Disc type: DVD-ROM
Disc size: 120mm
PM sent.
Madezuela
Need direct link for RS8F00 1.02 NM00100 firmware for ASUS BW-16D1X-U"
Post by Madezuela » Thu Sep 18, 2025 5:04 pm
I'm new to this and really haven't got much clue on what I'm doing apart from what Deepseek is telling me, and its telling me to ask the below , can someone please help?
I am trying to enable LibreDrive. I have SDFtool Flasher 1.3.6, but I cannot find a working download link for the correct firmware file HL-DT-ST-BD-RE_RS8F00_1.02-NM00100-212011021039.bin. All external links I find are dead. Can someone please share a direct link?"
currrent drive info
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DGDL118135WL
Re: Need direct link for RS8F00 1.02 NM00100 firmware for ASUS BW-16D1X-U"
Post by Coopervid » Thu Sep 18, 2025 5:27 pm
Madezuela wrote: Thu Sep 18, 2025 5:04 pm Hello,
currrent drive info
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
PM sent. It will enable libredrive and UHD ripping.
Madezuela
Re: Pioneer RS8F00
Post by Madezuela » Thu Sep 18, 2025 7:47 pm
thank you @coopervid!! legend!!!
The drive now shows LibreDrive enabled as per below, however dvds are ok, but tried 2 Blu-rays and it starts off and after a little while seems to get stuck the power light blinks and after a little while just says: "0 titles saved, 27 failed""
Do you know why?
sample the Makemkv logs:
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '8392212480'
Failed to save title 0 to file D:/Video
below is the new Drive Information: (previously knows as ASUS Product: BW-16D1X-U, Drive platform: Pioneer RS8F00)
new after flashing
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.02
Firmware date: 2022-03-07
Highest AACS version: 21
Drive platform: RS8F01
Firmware version: 1.02/ID43
Re: Pioneer RS8F00
Post by MartyMcNuts » Fri Sep 19, 2025 7:15 am
Madezuela wrote: Thu Sep 18, 2025 7:47 pm thank you @coopervid!! legend!!!
Do you know why?
new after flashing
OS device name: E:
Revision: 1.02
Most likely the drive is running out of juice and disappears for a moment. Could be caused by a dirty disc or simply not getting enough constant power.
1. Try cleaning the disc.
2. Use USB-C port if possible. If not, use USB 3 ports direct from motherboard (not case ports) or use an AC self-powered USB hub of at least 30W.
xflipx
Re: Pioneer RS8F00
Post by xflipx » Fri Oct 10, 2025 7:23 pm
@coopervid
The Drive I had died, got a replacement, but it seems to not like the FW. Is there a different one for the following?:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 82
Rabiddog
Re: Pioneer RS8F00
Post by Rabiddog » Thu Oct 30, 2025 10:40 am
Just purchased this drive asus BW-16D1X-U makemkv shows this info
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Looking for the correct firmware to flash
Any help will be gladly appreciated thanks
Re: Pioneer RS8F00
Post by Coopervid » Thu Oct 30, 2025 8:59 pm
xflipx wrote: Fri Oct 10, 2025 7:23 pm @coopervid
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
Re: Pioneer RS8F00
Post by Coopervid » Thu Oct 30, 2025 9:01 pm
Rabiddog wrote: Thu Oct 30, 2025 10:40 am Just purchased this drive asus BW-16D1X-U makemkv shows this info
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
PM sent.
hrldhrldhrld
Re: Pioneer RS8F00
Post by hrldhrldhrld » Fri Oct 31, 2025 1:42 pm
Also just bought this drive assuming it would be simple to flash.
Any help would be much appreciated
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
