Thought I had a duff disc, but just got another copy and it still fails to rip. It will play without issues in the same drive (using vlc player), so I don't think it's a physical problem with the disc.
I've tried using all the different protection modes, but all fail in the same way.
The error I get is....
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Calculated BUP offset for VTS #0 does not match one in IFO header.
IFO file for VTS #0 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
The info panel says..
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: DFDL149418WL
Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8A10
Firmware version: 1.14
Disc Information
Label: NIGHTCRAWLER
Timestamp: 2015-01-10 05:18:35
Protection: CSS/CPPM
Data capacity: 7.0 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
I'm using the latest version of makemkv (1.18.1)
Nightcrawler DVD fails to open disc
ttttt
Re: Nightcrawler DVD fails to open disc
It's probably Structural Protection. Some discs won't automatically open even if you try all of the built in protection removal modes.
Try opening the DVD in manual mode. Beginner guide for manual mode is here: viewtopic.php?p=132790#p132790
MakeMKV will show a list of all titles on the disc with title numbers and lengths. There can be up to 99 titles depending on the protection and most are fakes.
Check which titles are long enough to be a movie and try them one-by-one by typing the title number into the Manual Mode window. The fakes will throw an error, but eventually you will get to the real movie that MakeMKV can rip.
I had a disc that was throwing similar errors to you, the built in protection removal modes did not work but Manual Mode did. Heads up the real title on my disc was #55, so it can take a while.
16442496
Nordic version must be different. Rip just fine with no errors. MakeMKV 1.18.1, Linux.
Also gddrescue make ISO copy without any problem.
Disc Information
Label: NIGHTCRAWLER_NOR_SWE_FIN_DAN
Timestamp: 2014-12-22 12:47:58
Data capacity: 7.71 Gb
Disc type: DVD-ROM
Disc size: 120mm
and lsdvd say:
Disc Title: NIGHTCRAWLER_NOR_SWE_FIN_DAN
Title: 01, Length: 00:00:29.720 Chapters: 01, Cells: 01, Audio streams: 01, Subpictures: 00
Title: 02, Length: 00:00:23.000 Chapters: 01, Cells: 01, Audio streams: 01, Subpictures: 00
Title: 03, Length: 00:00:22.200 Chapters: 01, Cells: 01, Audio streams: 01, Subpictures: 00
Title: 04, Length: 00:00:38.440 Chapters: 01, Cells: 01, Audio streams: 01, Subpictures: 00
Title: 05, Length: 00:01:50.280 Chapters: 02, Cells: 02, Audio streams: 01, Subpictures: 04
Title: 06, Length: 00:02:19.280 Chapters: 02, Cells: 02, Audio streams: 01, Subpictures: 04
Title: 07, Length: 00:01:57.240 Chapters: 02, Cells: 02, Audio streams: 01, Subpictures: 04
Title: 08, Length: 01:52:45.600 Chapters: 16, Cells: 17, Audio streams: 02, Subpictures: 04
Title: 09, Length: 00:05:02.880 Chapters: 02, Cells: 02, Audio streams: 01, Subpictures: 04
DVDDiscID: d5f48d4fa27df7a12b0c8811bd12c1a9
Longest track: 08
Try with different drive if you have any.
Disc Information
Disc type: DVD-ROM
Disc size: 120mm
and lsdvd say:
Longest track: 08
Ezatoka
Try using a different DVD opening mode
