Attack On Titan - All Discs showing debug codes
mcleveland92
Post by mcleveland92 » Sat May 17, 2025 4:48 am
Hi everyone,
I noticed in previous threads that others were showing issues ripping Attack On Titan from their personal collection.
I believe I am taking the proper steps to avoid these kinds of problems, but I would like to see if this can be resolved. Year after year, others seem to come across these same issues with this amazing show.
Can someone help me figure this out?
I noticed that while watching some of the episodes, minutes of the video are skipped. I'm pretty sure the reason is tied to these debug codes.
While MakeMKV is moving episodes or the full video file to the output folder — whether from an encrypted or unencrypted backup — the following debug codes start repeating. This appears to happen during the copy/mux phase of the process:
DEBUG: Code 3199971767 at ,^Vpp7}N2T\F|:213132537
DEBUG: Code 0 at XwRB"fq2dQyUyTa|}]i:121261911
... (continues)
MakeMKV log contains wrote: C:\Users\USER/MakeMKV_log.txt
DEBUG: Code 3 at u%~+41nw7Z$>\(rT@7Hdjpjz:29395310
SDF  v098: HL-DT-ST_BD-RE_BP60NB10_1.02_212005070935_SIK06O5975642
Disc Info – Attack on Titan Season 01, Disc 4 (via KeyDB_Helper):
Getting disc info...
[(Disc Info)]
[DiscID]: 0xDAA44D7DF998CD4B10B53F845DFBE523B08A57BA
[Volume]: Attack_on_Titan_P2_D2
[Title]: Attack on Titan P2 D2
[Date]: 2014-07-24
[MediaKey]: 0x5FC4EEBAF58F29E5BE548E6981B0ADB7
[VID]: 0x9CECD59DE1737B0D1E80171EA61BD866
[VUK]: 0x19BDE16133885A26312E6387FAA0256E
[MKB]: 47
[UnitKey]: 1-0x6A5E7B4D57A659C23841F07828FED2BF
[KEYDB_STATUS]: (VALIDATED)
[STATUS]: complete
[DiscType]: BD
[MakeMKV SUPPORTED]: TRUE
New Additions in KEYDB.cfg (via KeyDB_Helper):
0x73A90A949B5B3A96E8C004D12AF4F65FA44AF70E = Attack_on_Titan_P1_D1 [Attack on Titan P1 D1] | D | 2014-04-23 | M | 0xEC6C0CB2E69BBB15ADFEE2B4FAD6AC10 | I | 0x9FAFE8651408DC70A95A080AB92FF49F | V | 0x759A36AB9F857F3AF50E1FEB5AE1A5B9 | U | 1-0x0EBEA7615C12909EC10AA6F02DB6B8CA; MKBv46 - VolumeSize: 48887103488 (BD)
0xC07975A997FD44529B937E302732D5CE4789F37D = Attack_on_Titan_P1_D2 [Attack on Titan P1 D1] | D | 2014-04-23 | M | 0x7D5407D7142BB4A4B58F1D059CD1B900 | I | 0xA6B1E0209B35FAD7B4019811A933CC97 | V | 0x3BA5CF927EFE0DD1271CFDC0A36E4CC5 | U | 1-0x02ECE35E758F862566C434CE868D8701; MKBv46 - VolumeSize: 45939687424 (BD)
0x7CE3575C35EF327DEF5F543FE0B7D4C8602364E2 = Attack_on_Titan_P2_D1 [Attack on Titan P2 D1] | D | 2014-07-24 | M | 0xFF72F2418780C41500BDA80422C2F4EC | I | 0x366417EED58EEDEFDB7A9FF5AEF00F74 | V | 0xAAC7C37617759875803CC81D830C5CDB | U | 1-0x5A1162400959384EF46DD06B8FD58C5C; MKBv47 - VolumeSize: 48379920384 (BD)
0xDAA44D7DF998CD4B10B53F845DFBE523B08A57BA = Attack_on_Titan_P2_D2 [Attack on Titan P2 D2] | D | 2014-07-24 | M | 0x5FC4EEBAF58F29E5BE548E6981B0ADB7 | I | 0x9CECD59DE1737B0D1E80171EA61BD866 | V | 0x19BDE16133885A26312E6387FAA0256E | U | 1-0x6A5E7B4D57A659C23841F07828FED2BF; MKBv47 - VolumeSize: 35342057472 (BD)
Steps I've taken:
  • Verified disc cleanliness and condition
  • Tested in latest MakeMKV version
  • Cross-checked with KeyDB_Helper and confirmed KEYDB.cfg entries
  • Tested playback in VLC — skipping persists at same timestamps
System Info:
  • Drive Model: LG BP60NB10
  • MakeMKV Version: 1.17.6
  • Operating System: Windows 11 x64
Any insights or suggestions would be greatly appreciated!
mcleveland92
Re: Attack On Titan - All Discs showing debug codes
Post by mcleveland92 » Wed May 28, 2025 7:40 pm
I don't know what avenues I should go with to get around these debug codes...
I don't know where to go from here :(
Post by dcoke22 » Sat Jul 05, 2025 1:17 pm
I've never noticed debug codes in the MakeMKV log to be a problem. Whenever I run into problems there's something other than just debug codes in the logs.
If you make a decrypted backup of a disc and if it completes without errors, you should have a copy of all the contents of the disc in a folder on your computer's storage. For blu-rays (and 4K UHDs) in the /BDMV/STREAM/ folder will be a bunch of files named #####.m2ts. These are the actual video files on the disc. They should be playable by VLC or most players.
In MakeMKV, if you highlight a title on the left, on the right one of the items will be the 'segment map' which will list one or more numbers. Those numbers correspond to the .m2ts files in the /BDMV/STREAM/ folder.
If you find one of the titles that has skipped video and you figure out the segment map for that title, you could play the .m2ts files directly. Do they contain the skipped video?
The MKVToolNix tools can operate on a decrypted backup of a disc made with MakeMKV. To try a different muxing engine, you could point MKVToolNix GUI at a decrypted backup and create .mkv files with MKVToolNix.
mcleveland92
Post by mcleveland92 » Sun Sep 14, 2025 7:48 am
Interesting new update -- just for wanting to see a different experience...
FFMPEG_ERROR: FFDEC000: [truehd @ 0x100c06050] No restart header present in substream 0.
FFMPEG_ERROR: FFDEC000: [truehd @ 0x100c06050] channel count mismatch
FFMPEG_ERROR: FFDEC000: [truehd @ 0x11ce31270] No restart header present in substream 0.
FFMPEG_ERROR: FFDEC000: [truehd @ 0x11ce31270] channel count mismatch
FFMPEG_ERROR: FFDEC000: [truehd @ 0x11ce2d250] No restart header present in substream 0.
FFMPEG_ERROR: FFDEC000: [truehd @ 0x11ce2d250] channel count mismatch
FFMPEG_ERROR: FFDEC000: [truehd @ 0x11ce32b20] No restart header present in substream 0.
FFMPEG_ERROR: FFDEC000: [truehd @ 0x11ce32b20] channel count mismatch
FFMPEG_ERROR: FFDEC000: [truehd @ 0x11ce27c70] No restart header present in substream 0.
FFMPEG_ERROR: FFDEC000: [truehd @ 0x11ce27c70] channel count mismatch
FFMPEG_ERROR: FFDEC000: [truehd @ 0x11ce2dde0] No restart header present in substream 0.
FFMPEG_ERROR: FFDEC000: [truehd @ 0x11ce2dde0] channel count mismatch
I found this coming up on the MacOS MakeMKV version which aligns with experiencing keyframes for audio for all Discs when using MakeMKV. Is there anyway this issue can be looked into from a developer perspective?
mcleveland92
Post by mcleveland92 » Sun Sep 14, 2025 7:00 pm
Just so I follow-up with everyone, and hopefully helps others trying to work Attack on Titan copying over...due to the last error being with FFMPEG_ERROR I went over to https://ffmpeg.org and read their documentation and decided to create a script that would remux each unencrypted backup. A question that is now being raised for me is... does MakeMKV use an older version of FFMPEG, because this worked flawlessly. I did use ffmpeg 8.0
#!/bin/bash
# Common metadata
show="Attack on Titan"
season=1
base_in="/Users/$USER/Movies/backup/Attack_on_Titan_P2_D1/BDMV/STREAM"
base_out="/Users/$USER/Movies/extracted_aot"
# Episode 20
ffmpeg -i "$base_in/00020.m2ts" \
-map 0 -map -0:s:1 \
-metadata title="$show - S01E20 - Erwin Smith - The 57th Exterior Scouting Mission" \
-metadata show="$show" \
-metadata season_number=$season \
-metadata episode_id="S01E20" \
-metadata episode_sort=20 \
-metadata:s:a:0 language=eng -metadata:s:a:1 language=eng \
-metadata:s:a:2 language=jpn -metadata:s:a:3 language=jpn \
-metadata:s:s:0 language=eng \
-c copy "$base_out/$show - S01E20 - Erwin Smith - The 57th Exterior Scouting Mission.mkv"
# Episode 21
ffmpeg -i "$base_in/00021.m2ts" \
-metadata title="$show - S01E21 - Crushing Blow - The 57th Exterior Scouting Mission" \
-metadata episode_id="S01E21" \
-metadata episode_sort=21 \
-c copy "$base_out/$show - S01E21 - Crushing Blow - The 57th Exterior Scouting Mission.mkv"
# Episode 22
ffmpeg -i "$base_in/00022.m2ts" \
-metadata title="$show - S01E22 - The Defeated - The 57th Exterior Scouting Mission" \
-metadata episode_id="S01E22" \
-metadata episode_sort=22 \
-c copy "$base_out/$show - S01E22 - The Defeated - The 57th Exterior Scouting Mission.mkv"
Post by dcoke22 » Mon Sep 15, 2025 2:06 pm
It is my understanding that the Mac and Windows versions of MakeMKV have a versions of ffmpeg packaged with them. The Linux version of MakeMKV uses the version of ffmpeg on the system. I don't know the version details of ffmpeg in the Mac and Windows versions.
mcleveland92
Post by mcleveland92 » Tue Sep 16, 2025 4:15 am
Then I might just try to start ripping my discs off a Linux OS with MakeMKV so that I can have up-to-date ffmpeg working with MakeMKV.
Who knows MakeMKV ffmpeg version currently being used and then the roadmap of updates of it?
