If by this you mean close the Helper program, reopen the Helper program, and click on Disc Info, no, it still gets stuck at the same point.SamuriHL wrote: Sat Sep 13, 2025 1:45 pm Just kill it and try it again and it should work now that the drive's been added.
Public KeyDB Disc Submissions
koberulz
lspe01
Another dump, this time for In My Skin (2002) 4K UHD is available here: https://www.mediafire.com/file/67j78563 ... 2.tgz/file
Grahamdoh
Then you may need to run FindVUK ValidateDisc in the FindVUK sub-folder where the KeyDB Helper.exe lives manually from a command prompt. Otherwise it'll keep getting stuck until the drive is added. This is completely outside of my control and is a FindVUK issue.koberulz wrote: Sat Sep 13, 2025 2:22 pmIf by this you mean close the Helper program, reopen the Helper program, and click on Disc Info, no, it still gets stuck at the same point.SamuriHL wrote: Sat Sep 13, 2025 1:45 pm Just kill it and try it again and it should work now that the drive's been added.
Grahamdoh
https://drive.google.com/drive/folders/ ... Q4FV9K_C0p
Stateline Motel from Shameless
Wrack and Ruin Discs 1,2&3 from Eureka
keydb_helper
That is an interesting idea. To be honest I thought the AACS 1.0 host cert/key pair bundled with MakeMKV was still viable even with MKBv82.SamuriHL wrote: Sat Sep 13, 2025 1:34 pm If I had to venture a guess, it MIGHT be because of the host cert situation. Up until now, LibreDrive wasn't a requirement for Blu-rays and MakeMKV. And while there's a known device key that works with MKB v82, there isn't afaik a known host cert. Maybe Mike decided to wait until he can acquire a new host cert. Who knows but that's the only thing that makes sense to me.
Hey hiro0077, file attachments are not really usable on the forum so no one can download your disc dump file. That is why I asked for disc dump files to be provided via external file hosts. Thank you for remembering to provide the MKB_RO.inf file though. Please upload your disc dump file to Google Drive and reply with the link.hiro0077 wrote: Sat Sep 13, 2025 1:51 pm Dump (.tgz): attached here
MKB_RO.inf (zipped, ~131 MB): ...
(If dump <1 MB, MKB_RO.inf is included inside the archive, otherwise please use the provided external link.)
Thanks lspe01, the 21E2 variant of In My Skin has been added to the public keydb.lspe01 wrote: Sat Sep 13, 2025 6:55 pm Another dump, this time for In My Skin (2002) 4K UHD is available here: ...
Hey Grahamdoh, thanks for the disc dump files. All four discs have been added to the public keydb.Grahamdoh wrote: Sat Sep 13, 2025 10:11 pm Stateline Motel from Shameless
- Do not submit Stranger Things S2D2, S4D3, or S5D2
minona
Saint248
Materialist Movie TGZ file
https://drive.google.com/file/d/1f_fLGB ... sp=sharing
koberulz
Subfolder? All I have is the executable.SamuriHL wrote: Sat Sep 13, 2025 9:55 pmThen you may need to run FindVUK ValidateDisc in the FindVUK sub-folder where the KeyDB Helper.exe lives manually from a command prompt. Otherwise it'll keep getting stuck until the drive is added. This is completely outside of my control and is a FindVUK issue.koberulz wrote: Sat Sep 13, 2025 2:22 pmIf by this you mean close the Helper program, reopen the Helper program, and click on Disc Info, no, it still gets stuck at the same point.SamuriHL wrote: Sat Sep 13, 2025 1:45 pm Just kill it and try it again and it should work now that the drive's been added.
No you don't. The very first thing that happens when you run the executable is it downloads and extracts findvuk to a subfolder where the executable is. Anyway this is all off topic in this thread. If you need more help with it open a new thread and I'll see what I can do.koberulz wrote: Subfolder? All I have is the executable.
koberulz
Ah, I was just running the executable without unzipping it, which may have been the problem. Moot point now, since all three discs are available in the database.SamuriHL wrote: Sun Sep 14, 2025 1:21 pm No you don't. The very first thing that happens when you run the executable is it downloads and extracts findvuk to a subfolder where the executable is.
I mean...the very first instruction in the post for the download is....koberulz wrote: Sun Sep 14, 2025 1:50 pm Ah, I was just running the executable without unzipping it, which may have been the problem. Moot point now, since all three discs are available in the database.
keydb_helper
Hey minona, thanks for the disc dump. The 20FA variant of Thunderbolts has been added to the public keydb.
Hey Saint248, I think you forgot to include the link to your disc dump file... Remember, attachments are not an option for disc dump files.
MKVDUDE
johnpinker@yahoo.com
A few Severin discs. BU40N drive.
Night Of The Damned
https://drive.google.com/file/d/1VTXWmS ... drive_link
Baba Yaga
https://drive.google.com/file/d/1RCb_9u ... drive_link
Terror Creatures From Beyond The Grave
https://drive.google.com/file/d/1a0r49d ... drive_link
Devils Wedding Night
https://drive.google.com/file/d/156nYaA ... drive_link
Night Of The Damned
Baba Yaga
