Thank you very much. Will try tomorrow. I have read that even if I copy movie to Bluray XL bluray players (I use xbox series x) do not read them. Is is right? In that case the best case scenario for me is using this firmware to copy UHD and convert it to fit 50GB discs.Coopervid wrote: Mon Sep 08, 2025 4:30 pmPM sent. Will read UHD and write BDXL.matt12345 wrote: Mon Sep 08, 2025 11:54 am Dear @Coopervid
Is is possible to make it to write on 100gb disc and to be readable in bluraplayer:Aktualny profil: BD-ROM
Producent: PIONEER
Produkt: BD-RW BDR-UD03
Wersja: 1.14
Numer seryjny: TJDL356149WL
Data firmware: 2020-06-15
Flagi szyfrowania bus: 1B
Najwyższa wersja AACS: 63
Drive platform: RS8511
Firmware version: 1.14
Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
matt12345
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Much better off ripping and storing the movie on a hard drive. Can you connect USB hard drives to your xbox?matt12345 wrote: Mon Sep 08, 2025 8:44 pmThank you very much. Will try tomorrow. I have read that even if I copy movie to Bluray XL bluray players (I use xbox series x) do not read them. Is is right? In that case the best case scenario for me is using this firmware to copy UHD and convert it to fit 50GB discs.
Marty is absolutely right. There is just 1 player that can play 100GB discs. A few 66GB but most only 50GB. And burning is expensive and most burns have trouble at the layer break. If you still want to burn regardless then read this:
https://forum.doom9.org/showthread.php?t=185539&page=19
matt12345
Thank youMartyMcNuts wrote: Tue Sep 09, 2025 4:55 amMuch better off ripping and storing the movie on a hard drive. Can you connect USB hard drives to your xbox?matt12345 wrote: Mon Sep 08, 2025 8:44 pmThank you very much. Will try tomorrow. I have read that even if I copy movie to Bluray XL bluray players (I use xbox series x) do not read them. Is is right? In that case the best case scenario for me is using this firmware to copy UHD and convert it to fit 50GB discs.
I have a buddy who is the same way. Sigh! Be sure to burn the 50GB discs that way as described. Disc quality is already very bad in this steep declining market.matt12345 wrote: Tue Sep 09, 2025 11:42 amThank youMartyMcNuts wrote: Tue Sep 09, 2025 4:55 amMuch better off ripping and storing the movie on a hard drive. Can you connect USB hard drives to your xbox?matt12345 wrote: Mon Sep 08, 2025 8:44 pm
Thank you very much. Will try tomorrow. I have read that even if I copy movie to Bluray XL bluray players (I use xbox series x) do not read them. Is is right? In that case the best case scenario for me is using this firmware to copy UHD and convert it to fit 50GB discs.Actually I have Plex server too but somehow i find somthing magic in getting movie box from shelf and putting disc on.
Micky12
I can obtain a new (old) 43890 drive which has a pioneer in it.
Should I buy it an is could you please help mit to unlock it for uhd?
If yes, I will buy it immediately.
There is a shop in my town and no one expects to see it there
Thx and greetings
Micky.
I forgot…. my new 43888 sucks because the LG drive doesn’t read all my dics.
My old 43888 with pioneer died.
Thx and greetings
Micky.
Sure. Go ahead and post again.Micky12 wrote: Sun Sep 14, 2025 6:40 am Hi,
There is a shop in my town and no one expects to see it there.
Thx and greetings
Micky.
Micky12
That’s great
Thank you.
Tomorrow I will see if the drive is still there.
That’s great
Micky12
Hey,
It worked, the drive was there and I bought it.
Could you please help me?
These are the infos from MakeMKV:
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.14
Serienummer: ALDL451403WL
Firmware-Datum: 2020-06-15
Highest AACS version: 76
Keine Disk eingelegt
Thank you very much and greetings Mick
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.14
You have it in a couple of minutes...Micky12 wrote: Mon Sep 15, 2025 3:38 pm Hey,
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.14
Reload the page so you see your PM.
Micky12
Thank you very very much cooper.
I´ll try it and I´m sure it will work.
Best greetings Micky.
Make sure to follow the tutorial by the book and it will work. You need to take away all power sources to it after flashing!Micky12 wrote: Mon Sep 15, 2025 4:23 pm Thank you very very much cooper.
Micky12
Works very good thank you very much.
The 43890 comes with an external power supply or you can use the cable with both usb plugs to attach to the computer.
I’ll now try a 86GB disc.
I’m convinced that it will work. My broken UD04 always does.
Greetings Micky.
Greetings Micky.
Micky12
