Public KeyDB Disc Submissions
koberulz
Post by koberulz » Sat Sep 13, 2025 2:22 pm
SamuriHL wrote:
Sat Sep 13, 2025 1:45 pm
Just kill it and try it again and it should work now that the drive's been added.
If by this you mean close the Helper program, reopen the Helper program, and click on Disc Info, no, it still gets stuck at the same point.
lspe01
Post by lspe01 » Sat Sep 13, 2025 6:55 pm
Another dump, this time for In My Skin (2002) 4K UHD is available here: https://www.mediafire.com/file/67j78563 ... 2.tgz/file
Grahamdoh
Post by Grahamdoh » Sat Sep 13, 2025 9:53 pm
Post by SamuriHL » Sat Sep 13, 2025 9:55 pm
Then you may need to run FindVUK ValidateDisc in the FindVUK sub-folder where the KeyDB Helper.exe lives manually from a command prompt. Otherwise it'll keep getting stuck until the drive is added. This is completely outside of my control and is a FindVUK issue.
Grahamdoh
Post by Grahamdoh » Sat Sep 13, 2025 10:11 pm
https://drive.google.com/drive/folders/ ... Q4FV9K_C0p
Stateline Motel from Shameless
Wrack and Ruin Discs 1,2&3 from Eureka
keydb_helper
Post by keydb_helper » Sun Sep 14, 2025 4:37 am
SamuriHL wrote:
Sat Sep 13, 2025 1:34 pm
If I had to venture a guess, it MIGHT be because of the host cert situation. Up until now, LibreDrive wasn't a requirement for Blu-rays and MakeMKV. And while there's a known device key that works with MKB v82, there isn't afaik a known host cert. Maybe Mike decided to wait until he can acquire a new host cert. Who knows but that's the only thing that makes sense to me.
That is an interesting idea. To be honest I thought the AACS 1.0 host cert/key pair bundled with MakeMKV was still viable even with MKBv82.
hiro0077 wrote:
Sat Sep 13, 2025 1:51 pm
Dump (.tgz): attached here
MKB_RO.inf (zipped, ~131 MB): ...
(If dump <1 MB, MKB_RO.inf is included inside the archive, otherwise please use the provided external link.)
Hey hiro0077, file attachments are not really usable on the forum so no one can download your disc dump file. That is why I asked for disc dump files to be provided via external file hosts. Thank you for remembering to provide the MKB_RO.inf file though. Please upload your disc dump file to Google Drive and reply with the link.
Another dump, this time for In My Skin (2002) 4K UHD is available here: ...
Thanks lspe01, the 21E2 variant of In My Skin has been added to the public keydb.
Hey Grahamdoh, thanks for the disc dump files. All four discs have been added to the public keydb.
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
minona
Post by minona » Sun Sep 14, 2025 6:58 am
Japanese 4K UHD Thunderbolts
Saint248
Post by Saint248 » Sun Sep 14, 2025 7:28 am
Materialist Movie TGZ file
koberulz
Post by koberulz » Sun Sep 14, 2025 12:28 pm
Subfolder? All I have is the executable.
Post by SamuriHL » Sun Sep 14, 2025 1:21 pm
koberulz wrote: Subfolder? All I have is the executable.
No you don't. The very first thing that happens when you run the executable is it downloads and extracts findvuk to a subfolder where the executable is. Anyway this is all off topic in this thread. If you need more help with it open a new thread and I'll see what I can do.
koberulz
Post by koberulz » Sun Sep 14, 2025 1:50 pm
Ah, I was just running the executable without unzipping it, which may have been the problem. Moot point now, since all three discs are available in the database.
Post by SamuriHL » Sun Sep 14, 2025 2:45 pm
I mean...the very first instruction in the post for the download is....
