Pioneer bdr 209 and Pioneer bdr 209m
R22D22
Re: Pioneer bdr 209 and Pioneer bdr 209m
Post by R22D22 »
Is it possible to bring it to UHD (4K) and what does it need :?:
Thank you very much :)
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.54
Firmware date: 2020-07-21
Bus encryption flags: 13
Highest AACS version: 54
Drive platform: RS8600
Firmware version: 1.54/ID60
Best regards
Viele Grüße
R22D22
Dragonnova
Post by Dragonnova »
Is it better to have two Pioneer BDR 209-DBKs or one Pioneer BDR 209-DBK and one LG BU40N? I have a limited budget and have to decide between one of these two options.
R22D22 wrote: Sat Sep 13, 2025 12:11 am Is it possible to bring it to UHD (4K) and what does it need :?:
Revision: 1.54
PM sent.
Dragonnova wrote: Sun Sep 14, 2025 10:21 am Is it better to have two Pioneer BDR 209-DBKs or one Pioneer BDR 209-DBK and one LG BU40N? I have a limited budget and have to decide between one of these two options.
Your decision. The Pioneer will rip hard to read discs while thr BU40 will rip faster when there is no problem to read the disc. 209 can be flashed to read UHDs as well. I personally would go with the Pioneers and flash both for UHD.
R22D22
Post by R22D22 »
Coopervid wrote: Mon Sep 15, 2025 9:10 amPM sent.
Thank you very much. Flashing was successful 8)
Currently I can't answers PM's (locked). For the case, exist the original firmware for the drive :?: :)
Best regards
Viele Grüße
R22D22
R22D22 wrote: Wed Sep 17, 2025 12:25 am
Yes. Contact me in case you have to return it and you can flash it back.
tomrail
Post by tomrail »
@Coopervid could you send me the files please my data below
Laufwerksinformation
OS-Gerätename: J:
Produzent: PIONEER
Produkt: BD-RW BDR-209D
Revision: 1.34
Serienummer:
Firmware-Datum: 2016-04-25
Markierungen der Bus-Verschlüsselung: 13
Firmware version: 1.34/ID61
Keine Disk eingelegt
tomrail wrote: Wed Sep 17, 2025 1:45 pm @Coopervid could you send me the files please my data below
OS-Gerätename: J:
Produzent: PIONEER
Revision: 1.34
Serienummer:
PM is coming. Reload your brower in a minute or so.
tomrail
Post by tomrail »
Coopervid wrote: Wed Sep 17, 2025 2:06 pm
OS-Gerätename: J:
Produzent: PIONEER
Revision: 1.34
Serienummer:
Thanks it works
warwolf7
Post by warwolf7 »
i got
OS device name: E:
Revision: 1.34
Serial number: ****REDACTED****
Firmware date: 2016-04-25
can I crossflash it to enable uhd ripping? I downloaded the dvrflash utility, but it seems impossible to find bin firmware
PIONEER BDR-211 1.52/ID60 or PIONEER BDR-211 1.53/ID60
can someone help me? Thank you
warwolf7 wrote: Sun Sep 21, 2025 7:43 pm Hi,
i got
OS device name: E:
Revision: 1.34
PM sent.
phauturok
Post by phauturok »
Hi - is it possible to get this drive to read UHD. Thank you in advance.
Product: BD-RW BDR-209D
Revision: 1.10
Serial number:
Firmware date: 2013-09-10
Highest AACS version: 77
Firmware version: 1.10/ID61
pmccarenko
Post by pmccarenko »
Hello. Could you send me please the files for crossflash my drive to enable uhd ripping?
My Drive data below:
OS device name: F:
Revision: 1.10
Serial number:
phauturok wrote: Tue Sep 23, 2025 6:27 am Hi - is it possible to get this drive to read UHD. Thank you in advance.
Revision: 1.10
Serial number:
PM sent.
pmccarenko wrote: Wed Sep 24, 2025 12:35 pm Hello. Could you send me please the files for crossflash my drive to enable uhd ripping?
OS device name: F:
Revision: 1.10
Serial number:
PM sent.
