Flashed new Asus drive but...
grendel
Post by grendel » Fri Sep 12, 2025 3:48 pm
Hello everyone,
I just bought a new ASUS Bw-16d1ht because my old LG drive is broken.
But that's not all, I built a new PC, a new OS (Windows 11).
I quietly installed MakeMKV and my licence, and I flashed the drive with "ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin" from the famous "The all you need firmware pack.zip"
So everything seems clear but when I try to backup a BR I can't read it --> Cannot render the file using MPC-HC.
I certainly missed something but I don't know what.
If a good soul can point the right direction :)
Re: Flashed new Asus drive but...
Post by Coopervid » Fri Sep 12, 2025 4:21 pm
For ripping you need to use Makemkv. MPC is only for playing and you need to activate playing in Makemkv. View Preferences Integration.
grendel
Post by grendel » Fri Sep 12, 2025 10:54 pm
Maybe I wasn't clear enough.
I used MakeMKV to backup My BR disc.
It's once ripped to my SSD that I got the message "Cannot render the file".
It seems to be encrypted :/
Post by Billycar11 » Sat Sep 13, 2025 12:28 am
grendel wrote: Fri Sep 12, 2025 10:54 pm Maybe I wasn't clear enough.
did you make a mkv or a folder backup?
if you did a folder backup did you check decrypt?
grendel
Post by grendel » Sat Sep 13, 2025 11:39 am
Oh my god, it was just that, I forgot to click on decrypt while I backuped a disc :/
6 years on the same PC got my brain melting :)
But if I got a suggestion to tell to the dev, click the decrypt box always on.
Once again thank you !
Post by Billycar11 » Sat Sep 13, 2025 12:32 pm
grendel wrote: Sat Sep 13, 2025 11:39 am Oh my god, it was just that, I forgot to click on decrypt while I backuped a disc :/
FYI if you just forgot to check it you could have reopened it from the rip and then decrypt it so save your optical drive from some wear
And it would be much faster
grendel
Post by grendel » Sat Sep 13, 2025 12:47 pm
Thank you for the tip !
