Krull 4kuhd
Galactica-Actual
Krull 4kuhd
Post by Galactica-Actual » Fri Sep 12, 2025 2:23 pm
HI all
Got the steel book today of Krull 4kuhd (in the uk) make mkv says it cant rip it, as the volume key is unknown. I dont do a lot of this ripping, so i dont understand how to fix. Can anyone help?
Thanks.
Galactica-Actual
Re: Krull 4kuhd
Post by Galactica-Actual » Fri Sep 12, 2025 3:44 pm
Anyone? :D
Re: Krull 4kuhd
Post by MartyMcNuts » Sat Sep 13, 2025 2:17 am
HI all
Thanks.
The correct process is to submit the dump file via email to svq@makemkv.com and wait a few days for a decryption key to be added to MakeMKV's hashed keys.
Additionally, if you would like to help the community and your dump was created using a Libredrive enabled non Pioneer drive, you can make a post in the Public KeyDB Submission thread, mentioning the name of the dump file, the drive used to create the dump and also provide a download link for the dump file once you have uploaded it to a hosting site somewhere (such as Google drive, one drive, MediaFire etc).
Galactica-Actual
Re: Krull 4kuhd
Post by Galactica-Actual » Sat Sep 13, 2025 2:33 pm
It might be helpful, if you could tell me
What a Dump file is please?
How i create it
And how its exported.
Thanks.
Galactica-Actual
Re: Krull 4kuhd
Post by Galactica-Actual » Sat Sep 13, 2025 2:37 pm
Ok, i have found the dump file, do i submit the whole zipped file?
Re: Krull 4kuhd
Post by MartyMcNuts » Sun Sep 14, 2025 1:15 am
Yes
