LibreDrive for Pioneer drives
I guess my questions are: is it UHD capable for $25 and/or is it libredrive capable for not $25? I'm just confused trying to read the 1500+ posts and not making sense of it.
It will be released for free eventually but for now it's not publicNotJoseph wrote: Fri Sep 12, 2025 12:21 pm I guess my questions are: is it UHD capable for $25 and/or is it libredrive capable for not $25? I'm just confused trying to read the 1500+ posts and not making sense of it.
@billycar11 I bought a Pioneer drive from you and it was working fine a few months ago but can't use it to play or rip UHD anymore. I did not update any firmware. I'm wondering if it's because it says Firmware type: Original (unpatched) but confused because it does also say Status: Enabled under Libre Drive Information. Let me know how to proceed, thanks.
MakeMKV Info
When trying to rip UHD I get:
MakeMKV Info
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-S13JX
Revision: 1.03
Serial number: __________
Firmware date: 2022-07-26
Highest AACS version: 77
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.03/ID72
Disc Information
Label: DONT_LOOK_NOW
Timestamp: 2023-07-31 15:14:34
Protection: AACS2.0/C v77
Data capacity: 93.21 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80Code: Select all
MakeMKV v1.18.1 linux(x64-release) started
Saved AACS dump file as /home/slagathor/.MakeMKV/MKB20_v77_DON'T_LOOK_NOW_2E31.tgz
Failed to open disc-
something has changed in your setupslagathor wrote: Wed Sep 17, 2025 3:55 am @billycar11 I bought a Pioneer drive from you and it was working fine a few months ago but can't use it to play or rip UHD anymore. I did not update any firmware. I'm wondering if it's because it says Firmware type: Original (unpatched) but confused because it does also say Status: Enabled under Libre Drive Information. Let me know how to proceed, thanks.
MakeMKV Info
When trying to rip UHD I get:Code: Select all
Drive Information OS device name: /dev/sr0 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-S13JX Revision: 1.03 Serial number: __________ Firmware date: 2022-07-26 Bus encryption flags: 1B Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: RS9201 Firmware name: PIONEER BDR-213T Firmware type: Original (unpatched) Firmware version: 1.03/ID72 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes Disc Information Label: DONT_LOOK_NOW Timestamp: 2023-07-31 15:14:34 Protection: AACS2.0/C v77 Data capacity: 93.21 Gb Disc type: BD-ROM UHD Number of layers: 3 Bus encryption flags: 80
MakeMKV v1.18.1 linux(x64-release) started Using direct disc access mode Loaded content hash table, will verify integrity of M2TS files. Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive Saved AACS dump file as /home/slagathor/.MakeMKV/MKB20_v77_DON'T_LOOK_NOW_2E31.tgz LibreDrive compatible drive is required to open this disc - video can't be decrypted. Failed to open disc
either your on a new pc with no access to hk downloads
or your docker does not pass through libredrive commands
@billycar11 I did switch to Linux from Windows. Does the Linux version of MakeMKV not have access to HK downloads? I'd prefer not to have to use Windows if possible.
If it matters, I am using Arch Linux and installed according to these MakeMKV instructions. I've also tried using the AUR version of MakeMKV but get the same error regardless. I can play / rip Bluray just fine btw.
Anything I can do here to get this working?
You have to get your hk downloads working or make sure the docker passes through the drive fullyslagathor wrote: Thu Sep 18, 2025 10:56 pm @billycar11 I did switch to Linux from Windows. Does the Linux version of MakeMKV not have access to HK downloads? I'd prefer not to have to use Windows if possible.
Both show similar issues
All that can work on Linux fine it just a matter of having it setup correctly
Hi, first time posting.
Ive had my Pioneer 211UKB drive for years. This week I downloaded MKV fir the first time and ripped 4 movies no problem. Today I tried The Revenant but evertime it got to the end it failed. Tried 3 times.
Then disaster struck.
I googled FW and found a new version - 1.54 version. I downloaded and installed from 1.52 not realising what I was letting myself in for.
Now the drive fails to read UHDs.
I'm gutted.
Any help?
Regards.
I'm gutted.
Any help?
Regards.
You are f...ed and have to wait until Mike comes up with a solution. No ETA.Atmos wrote: Mon Sep 22, 2025 6:24 pm Hi, first time posting.
I'm gutted.
Any help?
Regards.
BD-RW BDR-XS07U ?
What about it?
I just boght an asus external drive and make mkv shows the following: Drive Information
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: edited out
Firmware date: 2020-07-21
Firmware version: ID76
I cannot flash any firmware. Is this drive supported at all? I just spent like $170 on this, so would be great if it is supported but just not added.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
sure just email me that infoAmethyst wrote: Fri Sep 26, 2025 10:47 am I just boght an asus external drive and make mkv shows the following: Drive Information
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
I just sent an email. Hope it got through.Billycar11 wrote: Fri Sep 26, 2025 12:59 pmsure just email me that infoAmethyst wrote: Fri Sep 26, 2025 10:47 am I just boght an asus external drive and make mkv shows the following: Drive Information
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
yup responded you should already have your flasher
Yup It works perfectly! Now I can start building my jelyfin library.
