I've been happily ripping 4Ks for about a year on and off, then recently bought some new ones.
Ripped 3 movies fine.
Then "The Substance" appeared to rip fine, but playback of the output file broke at about 45 mins in.
Then "Deadpool & Wolverine" failed with hash check errors.
Then "Get Out" failed with hash check errors.
In-between these failures, other films ripped successfully - and so did a fresh attempt at "The Substance", fuelling my denial that the drive was starting to fail.
Nevertheless, I eventually got a new drive. Because maybe it's those discs? Maybe it's that Linux thing?
Yeah... that original drive is failing. Don't be me, don't live in denial, drives fail.
Denial is a powerful thing
remoteneeded
Re: Denial is a powerful thing
Oh I've been in denial too. Wasted far too much time blaming a Windows update, blaming bad discs, blaming everything I could bar the drive. Eventually bought a new drive and all the problems went away. As you say, drive fail
baraktorvan
Yes indeed, they can fail certainly. I am sorry to hear it did die on you. I have 3 TeamGroup nvme and 2 Toshiba spinners. While I certainly trust both manufacturers and have for years, my external Backup drive is replaced every year just in case.
You seem like the right type of paranoid to appreciate https://www.grc.com/sr/spinrite.htmbaraktorvan wrote: Fri Sep 12, 2025 9:10 pm Yes indeed, they can fail certainly. I am sorry to hear it did die on you. I have 3 TeamGroup nvme and 2 Toshiba spinners. While I certainly trust both manufacturers and have for years, my external Backup drive is replaced every year just in case.
I use it to verify any new hard drives and occasionally on existing drives to make sure everything is still in working order.
