Mac OS 26 Beta
asr101
Mac OS 26 Beta
Post by asr101 » Mon Aug 25, 2025 9:41 pm
Has anyone been brave (foolish) enough to update to the beta of Mac OX 26 (Tahoe) and test MakeMKV on it?
Thanks for any responses.
bradvan
Re: Mac OS 26 Beta
Post by bradvan » Thu Sep 11, 2025 2:20 pm
I installed the macOS Tahoe 26.0 Release Candidate that was released on September 9. So far everything seems to be working normally using MakeMKV 1.18.1. I have used it on only one disc that was a 4K Blu Ray, and that one saved successfully.
WAYFLIX
Re: Mac OS 26 Beta
Post by WAYFLIX » Sat Sep 13, 2025 11:28 am
Yup it's working just fine with the RC! Only detail I have noticed is the icon doesn't conform to the new design language.
asr101
Re: Mac OS 26 Beta
Post by asr101 » Wed Sep 17, 2025 7:41 pm
Thanks for your updates! I was too busy to set up an external boot to test it this time around.
tokyokie
Re: Mac OS 26 Beta
Post by tokyokie » Tue Oct 07, 2025 7:48 am
tal
I just now tried it, and neither version 18.1 nor 18.2 would load. I got some language about make mkv being downloaded from the Web and could damage my machine, yadda yadda yadda, but I couldn't bypass it as I used to be able to do. I'm going to try install an earlier version of MacOS and see whether that works. If anybody knows of any work-arounds, I'd be most appreciative to learn then,
Re: Mac OS 26 Beta
Post by dcoke22 » Tue Oct 07, 2025 1:34 pm
tal
Presumably this method still works: Gatekeeper in macOS X 15 Sequoia
AvidMarxist
Re: Mac OS 26 Beta
Post by AvidMarxist » Sat Nov 22, 2025 8:16 pm
hi - i am running 26.1 and cannot get MakeMKV to open; I get the icon bouncing issue. When prompted for my password through GateKeeper, it won't even accept that. When trying to do the xattr command in terminal, the command completes, but MakeMKV still won't run. I have tried installing back to 1.17.0 and still have the issue. Has anyone had any luck here?
Batman&throbbin
Re: Mac OS 26 Beta
Post by Batman&throbbin » Sun Nov 23, 2025 1:13 am
Hi you might want to raise this with Asmcom towards the end of this thread
viewtopic.php?f=20&t=19387&hilit=Asmcom&start=1425
He mentions Tahoe 26.1 working OK
