Hash check failed messages
ChaosEnergy
Post by ChaosEnergy » Wed Sep 10, 2025 9:09 pm
Hey
last days I did several UHD full Backups without errors...(sadly Jellyfin only plays the movie, not the extras, seems i need to create lot of mkv during winter)
Now I have my first disc throwing me lots of errors
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Backing up disc into folder "A:/video/MakeMKV/backup/HOUSE_OF_THE_DRAGON_S1_D1"
Hash check failed for file 00058.m2ts at offset 266397696, file is corrupt.
Hash check failed for file 00058.m2ts at offset 277407744, file is corrupt.
Hash check failed for file 00058.m2ts at offset 281143296, file is corrupt.
Hash check failed for file 00058.m2ts at offset 283699200, file is corrupt.
Hash check failed for file 00058.m2ts at offset 297068544, file is corrupt.
Too many hash check errors in file 00058.m2ts.
Hash check for /BDMV/STREAM/00058.m2ts : 0.18% corrupt, 99.79% correct, 99.98% checked.
How can I get this fixed, and what does it mean at all
UPDATE
I reread the disc and then it was without thew hash error
but the party goes
now I have disc 2 giving me medium error
I copied the mentioned file, and saw a moment where read rate sunk for a second and then it reads further
- does makemkv stop the process or errorcorrection to fast?
- is there a way to just try this one file again?
i saw the website that you shall copy everything to the PC manually, but then its encrypted, i already have all decrypted, except this one file...can i mix them and save time?
The simple workaround is to copy all files from the disc to the hard drive manually, without MakeMKV running. If you succeed in this, there is a fast and simple way to convert such copy into encrypted MakeMKV backup that can be opened by MakeMKV later. See our forum for details.
So many hits with search, but none explaining what to do, when all encryppted files on disc or even better, how to find out what file to decrypt directly from the disc..
you see titles, chapters, sadly no information this chapter is file xyz
