Need Help with flashing Archgon BD-RE BU40N
frustratednoob
#1 Post by frustratednoob » Wed Sep 10, 2025 2:28 am
Hello, I am at my wits end with this flashing process. :shock: I have tried to use the flasher, the cmd prompts, and everything I could think of. I will attach a few screenshots of what I am seeing and dealing with. I can verify the drive works and is being show in file explorer, being seen in MakeMKV, but getting "No drive tool logic found in SDF.bin Internal error 0x8d000000" in cmd prompt. It does burn normal/bluray movies fine.
Re: Need Help with flashing Archgon BD-RE BU40N
#2 Post by MartyMcNuts » Wed Sep 10, 2025 5:31 am
frustratednoob wrote: Wed Sep 10, 2025 2:28 am Hello, I am at my wits end with this flashing process. :shock: I have tried to use the flasher, the cmd prompts, and everything I could think of. I will attach a few screenshots of what I am seeing and dealing with. I can verify the drive works and is being show in file explorer, being seen in MakeMKV, but getting "No drive tool logic found in SDF.bin Internal error 0x8d000000" in cmd prompt. It does burn normal/bluray movies fine.
Using Windows?
frustratednoob
#3 Post by frustratednoob » Wed Sep 10, 2025 10:44 am
Yes windows 11.
#4 Post by Coopervid » Wed Sep 10, 2025 1:09 pm
Post your Makemkv info. Did you make sure drive is empty and closed?
frustratednoob
#5 Post by frustratednoob » Wed Sep 10, 2025 5:16 pm
I think the images aren't working when I attach them
frustratednoob
#6 Post by frustratednoob » Wed Sep 10, 2025 5:28 pm
Product: BD-RE BU40N
Revision: 1.02
Serial number:
Bus encryption flags: 1F
Highest AACS version: 77
Drive platform: MT 1959
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Unrestricted read speed: Possible (with patched firmware
shortcut1999
#7 Post by shortcut1999 » Wed Sep 10, 2025 6:31 pm
Coopervid wrote: Wed Sep 10, 2025 1:09 pm
I am having the same issues as frustratednoob. Followed all guides online. did cmd prompt, powershell, sdf tool, Used billys flasher as well. no success. on windows 11 and tried 2 different installations of the sdf tool and windows 11. and disc bay was empty and closed.
OS device name: F:
Revision: 1.02
Serial number:
Highest AACS version: 76
#8 Post by Billycar11 » Wed Sep 10, 2025 9:31 pm
getting quite a few reports of this
not sure whats happening if its a not downloading sdf issue or they changed the cases again
im leaning towards a case issue....
trying something now on a few people
#9 Post by Billycar11 » Wed Sep 10, 2025 9:51 pm
well pretty sure the new archgon cases dont pass flashing commands through so they are getting removed from the guide
mike may be able to fix it like last time but who knows ill send him some info
frustratednoob
#10 Post by frustratednoob » Thu Sep 11, 2025 12:39 am
*crossing fingers*
#11 Post by Billycar11 » Thu Sep 11, 2025 2:11 am
frustratednoob wrote: Thu Sep 11, 2025 12:39 am *crossing fingers*
would likely not be soon
frustratednoob
#12 Post by frustratednoob » Thu Sep 11, 2025 2:44 am
Hopefully the cables and adapters do the trick
frustratednoob
#13 Post by frustratednoob » Fri Sep 12, 2025 12:18 am
Update. Got it flashed with adapter and SATA adapter. Drive was removed from shell and flashed using sdf flasher.
https://a.co/d/9irTZEJ
https://a.co/d/93ApeSA
Used these 2 and all it working and ripping! 🥹
johndoe75010
#14 Post by johndoe75010 » Sun Sep 14, 2025 10:52 pm
frustratednoob wrote: Fri Sep 12, 2025 12:18 am Update. Got it flashed with adapter and SATA adapter. Drive was removed from shell and flashed using sdf flasher.
I have the exact same drive, which firmware file did you use?
frustratednoob
#15 Post by frustratednoob » Mon Sep 15, 2025 2:58 am
1.03
