Asus BW-16D1X-U
Waldemar
Re: Asus BW-16D1X-U
#241 Post by Waldemar » Thu Jul 24, 2025 7:05 am
Hi Billy,
I've send the email, please check spam folder in case you have not received it... a lot of times it puts me there, for some reason unknown to me.
Edit got your reply thanks
Thanks.
BrW
octobat
Re: Asus BW-16D1X-U
#242 Post by octobat » Mon Aug 25, 2025 12:20 am
I just got the same drive today, how can I make it read UHD discs? Drive info below. Thank you!
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 82
Firmware version: ID76
Re: Asus BW-16D1X-U
#243 Post by Billycar11 » Mon Aug 25, 2025 12:34 am
octobat wrote: Mon Aug 25, 2025 12:20 am Hello,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Yes email me that drive info see email below
ylofters
Re: Asus BW-16D1X-U
#244 Post by ylofters » Thu Aug 28, 2025 1:49 pm
HI,
Just wanted to drop by and shout out Billy. I also have a Asus BW-16D1X-U and I was up and running with UHD discs within a couple of hours of reaching out to him.
Thanks again Billy!
N00bE
Re: Asus BW-16D1X-U
#245 Post by N00bE » Sun Sep 07, 2025 9:50 pm
I just purchased this drive and show the following:
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Disc Information
Label: JOURNEY_EDGE_OF_UNIVERSE
Timestamp: 2009-01-19 22:15:56
Protection: CSS/CPPM
Data capacity: 4.19 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 1 (PTP)
I assume that there is a Pioneer RS8F00 drive in the enclosure and the firmware would need to be flashed with the SDFtool Flasher (currently version 1.3.6). Once flashed with the correct firmware, then "Drive Platform: MT1959" will be displayed and I can backup my blu-ray discs using MakeMKV. Is this correct?
Re: Asus BW-16D1X-U
#246 Post by MartyMcNuts » Sun Sep 07, 2025 11:19 pm
N00bE wrote: Sun Sep 07, 2025 9:50 pm I just purchased this drive and show the following:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Disc Information
Disc type: DVD-ROM
Disc size: 120mm
No, you are totally wrong. You are mixing up two completely dfferent drive platforms. SDFtool flasher only works with MT1959 drives, think LG and some ASUS. Yours is a Pioneer and will always remain a Pioneer. Try contacting Billycar11 as he should be able to help you with this drive.
Re: Asus BW-16D1X-U
#247 Post by Billycar11 » Mon Sep 08, 2025 12:28 am
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Disc Information
Disc type: DVD-ROM
Disc size: 120mm
yes see my email below i have a flasher for you just send over that info
N00bE
Re: Asus BW-16D1X-U
#248 Post by N00bE » Mon Sep 08, 2025 1:45 pm
MartyMcNuts wrote: Sun Sep 07, 2025 11:19 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Disc Information
Disc type: DVD-ROM
Disc size: 120mm
Thanks for the clarification - greatly appreciated. I will message Billycar11.
JohnnyTerrible
Re: Asus BW-16D1X-U
#249 Post by JohnnyTerrible » Mon Sep 08, 2025 11:21 pm
Hi, I just got the follow drive.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL124013WL
Highest AACS version: 36
Could anyone help me out?
I'm backing up physical media that I own.
Re: Asus BW-16D1X-U
#250 Post by Billycar11 » Tue Sep 09, 2025 1:48 am
JohnnyTerrible wrote: Mon Sep 08, 2025 11:21 pm Hi, I just got the follow drive.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
yes email me that info see below for email
JohnnyTerrible
Re: Asus BW-16D1X-U
#251 Post by JohnnyTerrible » Tue Sep 09, 2025 8:08 pm
Email sent.
OneBadTexican
Re: Asus BW-16D1X-U
#252 Post by OneBadTexican » Wed Sep 10, 2025 2:59 am
I have tried to read as much as possible on this forum about flashing my newly obtained Asus BW-16D1X-U drive. However I keep reading different conflicting posts and I am confused.
I have emailed Billy several times but I have yet to receive a response. All I need to know is what will his flash program allow my drive to do and can my drive actually be flashed? I have read several posts that my drive has to have a manufacturing date of 2020 or later.
Can anyone please educate me? The following is the information that MakeMKV gives me. I have emailed Billy to buy his program but since he hasn't responded I am hoping you can tell me what capabilities I will have after using his program when and if he responds to my emails.
Asus BW-16D1X-U
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: RGDL025687WL
Firmware date: 2017-12-21
Highest AACS version: 76
Drive platform: RS8601
Firmware version: E111/ID76
zittrig
Re: Asus BW-16D1X-U
#253 Post by zittrig » Wed Sep 10, 2025 5:18 am
Your drive can be flashed. You've to wait until Billy is reacting, I think.
Re: Asus BW-16D1X-U
#254 Post by Billycar11 » Wed Sep 10, 2025 11:57 am
OneBadTexican wrote: Wed Sep 10, 2025 2:59 am I have tried to read as much as possible on this forum about flashing my newly obtained Asus BW-16D1X-U drive. However I keep reading different conflicting posts and I am confused.
Asus BW-16D1X-U
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
i respond to all my emails
wonder if you are one of the many that has full mailboxes and say i dont respond
JohnnyTerrible
Re: Asus BW-16D1X-U
#255 Post by JohnnyTerrible » Thu Sep 11, 2025 11:44 pm
Just wanted to give an update for other people looking to flash this drive. I bought my drive from my local microcenter on 9/5/2025. It's an ASUS BW-16D1X-U. See MakeMKV drive information below.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
If your drive matches these specs when you look at it on MakeMKV it *IS FLASH-ABLE* with the right flasher and firmware.
I went ahead and just made a private deal with another individual to send me the right flasher and firmware and it worked perfectly. I'm currently backing up my UHD bluray collection.
I saw a lot of back and fourth when doing research so I just wanted to CONFIRM this is flash-able.
