Elio UHD – Dump Submitted (MKB v77)
gparker0918
Post by gparker0918 » Tue Sep 09, 2025 11:09 pm
Good evening,
I’ve submitted a dump for the UHD disc “Elio” which failed to decrypt in MakeMKV. The disc uses MKB version 77.
Disc info:
- Title: Elio (UHD)
- MKB version: 77
- Dump filename: MKB20_v77_Elio_3EAC.tgz
- Drive: OS device name: \Device\CdRom0
Product: BD-RE BU40N
Revision: 1.00
Serial number:
Firmware date: 2116-12-20 15:28
Highest AACS version: 82
- LibreDrive status: Enabled
Firmware version: 1.00
The dump was emailed to svq@makemkv.com today.
Thanks for continuing to support the UHD community — really appreciate your work!
Re: Elio UHD – Dump Submitted (MKB v77)
Post by MartyMcNuts » Wed Sep 10, 2025 12:38 am
gparker0918 wrote: Tue Sep 09, 2025 11:09 pm Good evening,
Disc info:
- Title: Elio (UHD)
- MKB version: 77
Revision: 1.00
Serial number:
Thanks for emailing in the dump file.
Additionally, if you want to help out the community further, you can submit a post in the Public KeyDB Submission thread containing the dump file name, mentioning what drive model was used to create the dump file and providing a download link for the dump file will allow someone to add a record to the public KeyDB.
viewtopic.php?f=12&t=38293
WAYFLIX
Post by WAYFLIX » Wed Sep 10, 2025 8:26 pm
Disney has a new scheme numbering system on this one. 000,001,002.....instead of the old 800s. I am guessing 000 is correct.
ascent5398
Post by ascent5398 » Mon Oct 06, 2025 4:59 pm
Did you see if 000 was the correct file for United States users? This is the first time I have seen the non 800s as well.
Post by MartyMcNuts » Mon Oct 06, 2025 11:15 pm
WAYFLIX wrote: Wed Sep 10, 2025 8:26 pm Disney has a new scheme numbering system on this one. 000,001,002.....instead of the old 800s. I am guessing 000 is correct.
Before Disney stopped UHD discs coming to Australia, for most of them, 00004 was the correct playlist.
