Jurassic Park rebirth
csbond2
Post by csbond2 »
Just received my disc today and when I try to open it up it give me over 200 hash key errors. It would not give me a dump file to put on here. Could anybody help me figure out if the disc is bad or if it's just a new encryption.
Re: Jurassic Park rebirth
csbond2 wrote:
Wed Sep 10, 2025 12:09 am
Not new encryption and may not be a bad disc. This happens alot wihth UHD discs! Give the disc a good cleaning before trying again.
csbond2
Post by csbond2 »
MartyMcNuts wrote:
Wed Sep 10, 2025 12:21 am
Thanks for the response I'm working on another one right now. As soon as it finishes I will clean it and try it again. If it is a bad disc though this is the last time I'm ordering online I will buy them local from now on.
csbond2 wrote:
Wed Sep 10, 2025 12:23 am
Yep, I buy locally whenever I can and only online when not available in my local store (or in the case of Disney, discs are not available in Australia at all!!) Jurassic Park Rebirth isn't released here until October 8th!
But, yeah, those errors are usually fixed by cleaning the disc. If wiping it down with a soft microfibre cloth doesn't work, you may have to do a deep cleaning using soapy water.
csbond2
Post by csbond2 »
MartyMcNuts wrote:
Wed Sep 10, 2025 12:29 am
Just to let you know cleaning it seems to have worked. I appreciate all the answers that I got back I've been doing this stuff since 2004. But 4K blu-rays are rather new to me as far as this so I've got to get used to some of the procedures but thank you for your help
