Single VOB file to MKV?
DigitriX
Post by DigitriX »
Hello guys,
I have couple of promo music videos and I was wondering is there a way to transcode a single VOB file to MKV with MakeMKV?
And if not, can you recommend me some other software for transcoding single vob files to mkv ones.
Thanks in advance! :)
joe42
Re: Single VOB file to MKV?
Post by joe42 »
MakeMKV does not transcode, which means to decode and re-encode.
VOB is a container format. MKV is a container format. So what you need is to convert from one container format to another.
Have you tried "open file" on the VOB from MakeMKV?
Smithcraft
Post by Smithcraft »
MakeMKV might not be the right tool for the job. Perhaps mkvtoolnix would be better?
SC
DigitriX
Post by DigitriX »
From the home page:
MakeMKV is a format converter, otherwise called "transcoder". It converts the video clips from proprietary (and usually encrypted) disc into a set of MKV files, preserving most information but not changing it in any way.
I don't want to change anything in the file, just the containers.
And yes, I tried to open the single file with MakeMKV, but it doesn't work.
Any suggestions? :?
Romansh
Post by Romansh »
Smithcraft wrote:MakeMKV might not be the right tool for the job. Perhaps mkvtoolnix would be better?
SC
DigitriX
Post by DigitriX »
SC
Thank you! That's what I was looking for! :)
DigitriX
Post by DigitriX »
Hello again, guys...
Today I realized that, when using mkvtoolnix, the audio track is gone.
Help? :(
Romansh
Post by Romansh »
DigitriX wrote:Hello again, guys...
Help? :(
There's an Mkvtoolnix thread on doom9: http://forum.doom9.org/showthread.php?t=155732
Edit: and now Mkvtoolnix has its own forum -> https://www.bunkus.org/answers/
Smithcraft
Perhaps VOB2MPG might be a good start.
Otherwise, I'm wondering if these DVDs were encoded correctly, or the audio is interleaved into the video.
SC
chi.tran
Post by chi.tran »
try handbreak.fr
Smithcraft
Better yet - handbrake.fr
SC
Smithcraft
Or maybe even VOB2MKV?
SC
celavey
Post by celavey »
VOB is different from MKV when it comes to video quality.
Smithcraft
Could you please explain that a bit better?
SC
Sidrack
Post by Sidrack »
Have you tried using TSMuxer?
http://www.videohelp.com/tools/tsMuxeR
