Is ASUS BW-16D1HT Pro capable for quality scanning?
sherrypicket216
Post by sherrypicket216 » Tue Sep 09, 2025 2:32 pm
ASUS BW-16D1HT Pro capable for quality scanning using software like qpxtool?
Re: Is ASUS BW-16D1HT Pro capable for quality scanning?
Post by Woodstock » Tue Sep 09, 2025 3:01 pm
Define "quality scanning". It either reads a disk, or it doesn't.
Post by Coopervid » Tue Sep 09, 2025 3:12 pm
sherrypicket216 wrote: Tue Sep 09, 2025 2:32 pm ASUS BW-16D1HT Pro capable for quality scanning using software like qpxtool?
Yes, it will be if its an LG drive based on MT1959 (check Makemkv info) and you flash it to WH16NS58 V1.5. Use SDFToolFlasher from Marty. I will PM the firmware and also a link for VPTools which is a little nicer than qxptool. If your drive is a Pioneer drive this will not work.
