Is ASUS BW-16D1HT Pro capable for quality scanning?
sherrypicket216
ASUS BW-16D1HT Pro capable for quality scanning using software like qpxtool?
Re: Is ASUS BW-16D1HT Pro capable for quality scanning?
Define "quality scanning". It either reads a disk, or it doesn't.
Yes, it will be if its an LG drive based on MT1959 (check Makemkv info) and you flash it to WH16NS58 V1.5. Use SDFToolFlasher from Marty. I will PM the firmware and also a link for VPTools which is a little nicer than qxptool. If your drive is a Pioneer drive this will not work.sherrypicket216 wrote: Tue Sep 09, 2025 2:32 pm ASUS BW-16D1HT Pro capable for quality scanning using software like qpxtool?
