Need Help Identifying Platform for HL-DT-ST BP55EB40-EB52 Blu-ray Drive
Hello!
I recently bought a nearly new Blu-ray drive from a local reseller: HL-DT-ST BP55EB40, SVC Code: EB52.
When I connected it to MakeMKV, it didn’t show any LibreDrive information. I also tried SDFtoolFlasher, which reported that the drive isn’t based on the MT1959 platform.
I’m a bit puzzled. Is there a way to determine the platform this drive uses without disassemble it?
Any guidance or tips would be greatly appreciated—thanks in advance!
Ref: https://forum.makemkv.com/forum/viewtopic.php?t=37876
Information from MakeMKV v1.18.1:
OS device name: [REDACTED]
Current profile: CD-ROM
Product: BD-RE BP55EB40
Revision: 1.02
Serial number: WQ94 [REDACTED]
Highest AACS version: 71
Label in drive:
Manufactured: 2025.05.06 (May 2025)
ROM VER: 1.03
Revision: 1.02
Label in drive:
ROM VER: 1.03
Re: Need Help Identifying Platform for HL-DT-ST BP55EB40-EB52 Blu-ray Drive
It uses the MT1959 drive platform. Post the libredrive info section, which should be below the drive info section.xavierxyp wrote: ↑Mon Sep 08, 2025 3:09 pmHello!
Ref: viewtopic.php?t=37876
Revision: 1.02
Label in drive:
ROM VER: 1.03
maybe take out the CD-ROM which seem to be in the drive and keep the drive empty while looking up the info on MakeMKV
Thanks for the reply!MartyMcNuts wrote: ↑Tue Sep 09, 2025 4:59 amIt uses the MT1959 drive platform. Post the libredrive info section, which should be below the drive info section.
I’m still a bit confused though, since I don't see any additional information under the drive info section.
Did I possibly miss a step?
I’m also starting to wonder if there might be a mismatch somewhere, maybe it's just a labeling or firmware issue, or perhaps the actual hardware isn't exactly what the seller listed.
Is there any reliable way to verify the real hardware model without physically opening the drive?
Down the right hand side, should look similar to this:xavierxyp wrote: ↑Tue Sep 09, 2025 4:00 pmThanks for the reply!MartyMcNuts wrote: ↑Tue Sep 09, 2025 4:59 amIt uses the MT1959 drive platform. Post the libredrive info section, which should be below the drive info section.
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.00
Serial number: **REDACTED**
Firmware date: 2019-01-10
Highest AACS version: 82
Drive platform: RS8F01
Firmware version: 1.00/ID43
As you can see, there is the Drive Info and LibreDrive Info sections. Your drive should show MT1959 under drive platform.
If the Libredrive section is not showing, close MakeMKV, insert a blu-ray disc in to the drive, wait until Windows has initialised the disc (you can see it in windows explorer) then open up MakeMKV. Hopefully once MakeMKV sees the disc, it will show these sections.
Thanks for the suggestion.MartyMcNuts wrote: ↑Wed Sep 10, 2025 12:09 amIf the Libredrive section is not showing, close MakeMKV, insert a blu-ray disc in to the drive, wait until Windows has initialised the disc (you can see it in windows explorer) then open up MakeMKV. Hopefully once MakeMKV sees the disc, it will show these sections.
I tried, but unfortunately the LibreDrive section still doesn’t show up. Here's a screenshot of what I see below: https://imgur.com/a/R0aTmPE
Does MakeMKV have internet access? In preferences, ensure the box is checked.xavierxyp wrote: ↑Wed Sep 10, 2025 4:33 pmThanks for the suggestion.MartyMcNuts wrote: ↑Wed Sep 10, 2025 12:09 amIf the Libredrive section is not showing, close MakeMKV, insert a blu-ray disc in to the drive, wait until Windows has initialised the disc (you can see it in windows explorer) then open up MakeMKV. Hopefully once MakeMKV sees the disc, it will show these sections.
Yes, I've check about that. Unfortunately, the LibreDrive section still doesn't appear, even with that setting enabled.MartyMcNuts wrote: ↑Wed Sep 10, 2025 11:45 pmDoes MakeMKV have internet access? In preferences, ensure the box is checked.
Here's a snippet from the debug log:
Debug log started at Wed Sep 10 16:12:02 2025 , written by MakeMKV v1.18.1 win(x64-release)
001005:0000 MakeMKV v1.18.1 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\<REDACTED>/MakeMKV_log_1.txt
001003:0020 DEBUG: Code 0 at 2g`y)1d*msr{}#Bb:121276424
No SDF v097: HL-DT-ST_BD-RE_BP55EB40_1.02_WQ94_<REDACTED>
No auto SDF v097: HL-DT-ST_BD-RE_BP55EB40_1.02_WQ94_<REDACTED>
DEBUG: Code 0 at \c^YLv PcaLdd\XsJ:29396253
DEBUG: Code 0 at e!/TsMgD>)UEE`0S:213136746
DEBUG: Code 3 at u%~+41nw7Z$>\(rT@7Hdjpjz:29395310
SDF id v097: HL-DT-ST_BD-RE_BP55EB40_1.02_WQ94_<REDACTED>
Application exited at Sat Sep 13 06:06:57 2025
Is that drive connected internally or in an external enclosure?
If internally, can you try to use a different SATA cable? Or at least check, if the cables are connected correctly?
If external, what kind of enclosure is it?
It's a BP55EB40, essentially the same as the BP50NB40. It has it's own enclosure.
I also tried on another ARM64 Mac, but still no luck the LibreDrive section doesn’t show up in the GUI.xavierxyp wrote: ↑Mon Sep 08, 2025 3:09 pmInformation from MakeMKV v1.18.1:
Revision: 1.02
Label in drive:
ROM VER: 1.03
Then I tried `makemkvcon64.exe` in Windows:
PS > .\makemkvcon64.exe f -vvv -d H: --sdf-file=<REDACTED>\sdf.bin --info
Found sdf.bin version 0x98 at <REDACTED>\sdf.bin
Loaded SDF.bin version 0x98
No drive-specific logic found in SDF.bin
SDF.bin version: 0x0098
Drive Tool SDF not present
Drive Specific SDF not present
Identification SDF present-
Yours is the Chinese variant it's not flashablexavierxyp wrote: ↑Tue Sep 16, 2025 3:28 pmI also tried on another ARM64 Mac, but still no luck the LibreDrive section doesn’t show up in the GUI.xavierxyp wrote: ↑Mon Sep 08, 2025 3:09 pmInformation from MakeMKV v1.18.1:
Revision: 1.02
Label in drive:
ROM VER: 1.03
Then I tried `makemkvcon64.exe` in Windows:Any further suggestions on what I could try next?Code: Select all
PS > .\makemkvcon64.exe f -vvv -d H: --sdf-file=<REDACTED>\sdf.bin --info Found sdf.bin version 0x98 at <REDACTED>\sdf.bin Loaded SDF.bin version 0x98 No drive-specific logic found in SDF.bin SDF.bin version: 0x0098 Drive Tool SDF not present Drive Specific SDF not present Identification SDF present
