Is there a way to set the default output directory? Also is there a document somewhere that shows what settings can be added to settings.conf ?
Thanks -
Oh also is there a date when the linux version will exit beta? If I purchase a key will it be valid on the non-beta version (this is my first day of using makemk but it seems to work well).
How to set default output directory (linux version)
jojo1
crowfax
Re: How to set default output directory (linux version)
The key you buy now will be a lifetime key.
http://www.makemkv.com/buy/
As for the default output directory, it is possible to set it in the settings.conf I believe, but I'm away from my main machine right now. Perhaps someone else can post the appropriate string for setting it. If not I'll do it when I get home.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
jojo1
I think I found it:
app_DestinationDir
app_DestinationDir
jojo1
Hum. Doesn't work at all. If someone has suggestions on how to set the default output directory on the linux version I'd appreaciate hearing about ....
Bleh I figured it out; I'm an idiot.
