DUMP :: The Legend of Ochi (Die Legende von Ochi)
scarbrtj
Post by scarbrtj »
PG 2025 ‧ Family/Fantasy ‧ 1h 36m
MKB20_v82_Die_Legende_von_Ochi_BDC2.tgz
Re: DUMP :: The Legend of Ochi (Die Legende von Ochi)
scarbrtj wrote: Tue Sep 09, 2025 12:35 am The Legend of Ochi (Die Legende von Ochi)
Please don't create separate threads just to say you submitted the dump. If you meant to attach the dump file, that should not be done here.
The correct process is:
1. Email the dump file to svq@makemkv.com so that a key can be added to MakeMKV's internal key database.
2. Additionally, if you want to help out the community, you can submit a post in the Public KeyDB Submission thread containing the dump file name, mentioning what drive model was used to create the dump file and providing a download link for the dump file will allow someone to add a record to the public KeyDB.
keydb_helper
Post by keydb_helper »
Hey scarbrtj, the BDC2 variant of The Legend of Ochi (Die Legende von Ochi) was added to the public keydb on September 4. Grab the latest keydb and you should be able to process your disc
Public KeyDB Disc Submissions
