Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
matt12345
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Post by matt12345 »
Coopervid wrote: Mon Sep 08, 2025 4:30 pm
matt12345 wrote: Mon Sep 08, 2025 11:54 am Dear @Coopervid
Is is possible to make it to write on 100gb disc and to be readable in bluraplayer:
Aktualny profil: BD-ROM
Producent: PIONEER
Produkt: BD-RW BDR-UD03
Wersja: 1.14
Numer seryjny: TJDL356149WL
Data firmware: 2020-06-15
Flagi szyfrowania bus: 1B
Najwyższa wersja AACS: 63
Drive platform: RS8511
Firmware version: 1.14
PM sent. Will read UHD and write BDXL.
Thank you very much. Will try tomorrow. I have read that even if I copy movie to Bluray XL bluray players (I use xbox series x) do not read them. Is is right? In that case the best case scenario for me is using this firmware to copy UHD and convert it to fit 50GB discs.
matt12345 wrote: Mon Sep 08, 2025 8:44 pm
Much better off ripping and storing the movie on a hard drive. Can you connect USB hard drives to your xbox?
Marty is absolutely right. There is just 1 player that can play 100GB discs. A few 66GB but most only 50GB. And burning is expensive and most burns have trouble at the layer break. If you still want to burn regardless then read this:
https://forum.doom9.org/showthread.php?t=185539&page=19
matt12345
Post by matt12345 »
MartyMcNuts wrote: Tue Sep 09, 2025 4:55 am
Thank you :) Actually I have Plex server too but somehow i find somthing magic in getting movie box from shelf and putting disc on.
matt12345 wrote: Tue Sep 09, 2025 11:42 am
I have a buddy who is the same way. Sigh! Be sure to burn the 50GB discs that way as described. Disc quality is already very bad in this steep declining market.
Micky12
Post by Micky12 »
I can obtain a new (old) 43890 drive which has a pioneer in it.
Should I buy it an is could you please help mit to unlock it for uhd?
If yes, I will buy it immediately.
There is a shop in my town and no one expects to see it there ;).
Thx and greetings
Micky.
I forgot…. my new 43888 sucks because the LG drive doesn’t read all my dics.
My old 43888 with pioneer died.
Micky12 wrote: Sun Sep 14, 2025 6:40 am Hi,
Thx and greetings
Micky.
Sure. Go ahead and post again.
Micky12
Post by Micky12 »
That’s great 😀 Thank you.
Tomorrow I will see if the drive is still there.
Micky12
Post by Micky12 »
Hey,
It worked, the drive was there and I bought it.
Could you please help me?
These are the infos from MakeMKV:
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.14
Serienummer: ALDL451403WL
Firmware-Datum: 2020-06-15
Highest AACS version: 76
Keine Disk eingelegt
Thank you very much and greetings Mick
Micky12 wrote: Mon Sep 15, 2025 3:38 pm Hey,
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.14
You have it in a couple of minutes...
Reload the page so you see your PM.
Micky12
Post by Micky12 »
Thank you very very much cooper. :)
I´ll try it and I´m sure it will work.
Best greetings Micky.
Micky12 wrote: Mon Sep 15, 2025 4:23 pm Thank you very very much cooper. :)
Make sure to follow the tutorial by the book and it will work. You need to take away all power sources to it after flashing!
Micky12
Post by Micky12 »
Works very good thank you very much.
The 43890 comes with an external power supply or you can use the cable with both usb plugs to attach to the computer.
I’ll now try a 86GB disc.
I’m convinced that it will work. My broken UD04 always does.
Greetings Micky.
Micky12
Post by Micky12 »
Did I meant.
