Setting a default subtitle
mangry
Post by mangry »
Is there a way to mark a subtitle as the default track? (So it turns on automatically)
idontexist
Re: Setting a default subtitle
Post by idontexist »
That's funny - I see a lot of posts asking how to do the opposite.
Download the mkvmerge GUI toolset. Within there, run the MKVMerge tool and choose File> Header Editor. From there you can edit the individual header elements, and save them without having to re-output the entire file.
mangry
Post by mangry »
idontexist wrote:That's funny - I see a lot of posts asking how to do the opposite.
Yeah thanks, I meant get MakeMKV to do it - it takes enough time as it is.
Chetwood
Post by Chetwood »
Hopefully Mike will implement this when he adds stream reordering.
