This drive is UHD friendly?
sandro_rocha
Post by sandro_rocha »
Good morning. I found this drive for sale and wanted to know if it would be capable of reading UHD discs. Based on the information on the label, can you tell? I saw that some drives of this model with firmware 1.02 are "UHD friendly." If so, would it be possible to downgrade since this one has firmware 1.03? And if it is possible to downgrade, would the original firmware already work, or would I need to use the Make MKV firmware?
Re: This drive is UHD friendly?
sandro_rocha wrote: Mon Sep 08, 2025 1:50 pm Good morning. I found this drive for sale and wanted to know if it would be capable of reading UHD discs. Based on the information on the label, can you tell? I saw that some drives of this model with firmware 1.02 are "UHD friendly." If so, would it be possible to downgrade since this one has firmware 1.03? And if it is possible to downgrade, would the original firmware already work, or would I need to use the Make MKV firmware?
Man! Which drive?
sandro_rocha
Coopervid wrote: Mon Sep 08, 2025 4:29 pm
Man! Which drive?
https://ibb.co/HD5Q7qnc
I tried to attach the image but it didn't work.
sandro_rocha wrote: Tue Sep 09, 2025 11:24 am
Man! Which drive?
Most likely not libredrive / UHD capable because it's made before 2015. To be sure you should run Makemkv and copy and paste what "info" says in the right part of the window in your next post.
sandro_rocha
Coopervid wrote: Tue Sep 09, 2025 3:03 pm
Man! Which drive?
Unfortunately, I can't post this information. I found the drive for sale and wanted to know before buying. Where I live, it's hard to find 4K Blu-ray drives. Even at the time of their release, they were difficult to find.
sandro_rocha wrote: Tue Sep 09, 2025 4:36 pm
To be safe the drive must be manufactured in 2016 or late 2015. Don't buy it!
