Tokyofool
Re: Pioneer firmware update February 2023
Post by Tokyofool »
Tokyofool wrote: Fri Sep 05, 2025 1:58 pm
Coopervid wrote: Fri Sep 05, 2025 1:39 pm
Tokyofool wrote: Fri Sep 05, 2025 12:48 pm I have got a Pioneer BDR-212, I am able to use Makemkv to rip some Blu-ray Audio disk, but I think the drive is not LibreDrive enabled yet ...
OS device name: /dev/rdisk2
Current profile: BD-R SRM
Manufacturer: PIONEER
Product: BD-RW BDR-212U
Revision: 1.02
Serial number: BKDL006601WL
Firmware date: 2022-03-07
Highest AACS version: 81
Status: Possible, not yet enabled Drive platform: Pioneer RS8F01
Firmware version: ID83
Can someone provide me instructions on how to get the drive LibreDrive enabled?
Thanks in advance.
PM sent.
Thanks. Will try it later.
Successfully updated the firmware, worked well ripping a 4K disc. Thanks a lot!
EthanW
Post by EthanW »
Got a Pioneer BDR-212DBK, LibreDrive enabled but can someone provide me instructions on how to get UHD
Product: BD-RW BDR-212D
Revision: 1.00
Serial number:
Firmware date: 2019-01-10
Bus encryption flags: 13
Highest AACS version: 82
Drive platform: RS8F00
Firmware version: 1.00/ID61
EthanW wrote: Wed Sep 10, 2025 12:04 am Got a Pioneer BDR-212DBK, LibreDrive enabled but can someone provide me instructions on how to get UHD
Revision: 1.00
Serial number:
sure email me that drive info section see below
Tokyofool
Post by Tokyofool »
Thanks to the help here (especially from @Coopervid), I am able to have my BDR-212V LibreDrive enabled. I then bought a 2nd one-
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: DGDL028336WL
Firmware date: 2022-05-31
Firmware version: ID06
Can this drive be LibreDrive enabled? I have already got firmware for BDR-S12JBK, can I use the same 2 files? Or I need a different set of firmware?
Thanks in advance
Yes. Also PMed you.
nadious
Post by nadious »
So, I've managed to flash two LG drives that I had in the past couple of months. Both work and allow me to rip UHD. I found a post online where someone had the exact same drive I did, so it was pretty direct and made the process pretty simple with a simple tool and couple of clicks.
That being said, I've now run across this drive in my possession:
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: ADDL025929UC
Firmware date: 2020-08-20
Drive platform: RS8D30
Firmware version: 1.03
Is the drive able to be flashed to read UHD? And if so, what firmware do I need? I've tried to do my due diligence and try to find the answers before posting here, but not coming up with anything easily. I've tried reading a UHD disk as it is now, but it does not work, so I'm assuming I need to flash another firmware on it to make it work?
nadious wrote: Sun Sep 14, 2025 7:59 pm So, I've managed to flash two LG drives that I had in the past couple of months. Both work and allow me to rip UHD. I found a post online where someone had the exact same drive I did, so it was pretty direct and made the process pretty simple with a simple tool and couple of clicks.
Revision: 1.03
it can do UHD email me that drive info see below for contact details
dave1231
Post by dave1231 »
Hello Billycar11 or Coopervid!
I am hoping you can help me out with enabling LibreDrive + UHD. Information below:
OS device name: G:
Product: BD-RW BDR-209M
Revision: 1.54
Serial number: ***Redacted*** (I don't think this is necessary but lmk if it is)
Highest AACS version: 77
Firmware version: ID04
dave1231 wrote: Thu Sep 25, 2025 12:51 am Hello Billycar11 or Coopervid!
OS device name: G:
Revision: 1.54
Sure just email me that drive info see email below
sspell
Post by sspell »
Hi I have this drive would like it to do uhd mkv backup of uhd disc any help or will it work?
Product: BD-RW BDR-X12
Revision: 1.07
Serial number:
Firmware date: 2023-08-01
Drive platform: Pioneer RS9000
Firmware version: ID56
sspell wrote: Thu Sep 25, 2025 8:07 pm Hi I have this drive would like it to do uhd mkv backup of uhd disc any help or will it work?
Revision: 1.07
Serial number:
I answered you in the other thread. Please don't post the same thing in multiple threads!!
sspell
Post by sspell »
ok sorry but found the other tread after posting here.
sspell wrote: Thu Sep 25, 2025 11:58 pm ok sorry but found the other tread after posting here.
So? You only need to ask once. Someone will answer sooner or later.
lezbhonest
Post by lezbhonest »
Hi there, posting on here because my driver platform says "Pioneer". Honestly I am really new to this and doing my best to figure it out, but am lost. I tried to SDF tool and it says that the drive platform was MT1959 and wouldn't work. So then I tried the Asus modified tool and that didn't work either. That said "Erorr 1". Please help. Main computer is a mac, but I have an old windows 10 machine that works great.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Firmware version: ID76
nicholfd
Post by nicholfd »
lezbhonest wrote: Mon Sep 29, 2025 8:09 pm Hi there, posting on here because my driver platform says "Pioneer". Honestly I am really new to this and doing my best to figure it out, but am lost. I tried to SDF tool and it says that the drive platform was MT1959 and wouldn't work. So then I tried the Asus modified tool and that didn't work either. That said "Erorr 1". Please help. Main computer is a mac, but I have an old windows 10 machine that works great.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Contact coopervid or billycar11 directly & provide them the above drive information from MakeMKV. They can provide you with a flash "package" for it, to make the task simple. The software they provide runs on Windows - physical or virtual on macOS (I've flashed my drives from a MacBook Air, with a Windows 11 Pro ARM VM).
