The new beta key doesn't work
Finn-Again
Hi, I'm new here. I heard of this program for archiving my DVD collection and was excited to use it. The only problem is I have not gotten the chance to use it at all and I'm finding no information on how to get past the register key. I used the temporary that was posted recently and it's still "invalid." I don't know if I want to buy a key since I haven't even been able to use the free non-working version. How do I fix this and get the program to run? Please help I haven't been able to find any other recommended software to do the same thing this one is suppose to be able to do.
Re: The new beta key doesn't work
Let's get this straight - you used the current beta key that is in the topic MakeMKV is free while in beta, and it did not work?
Gio1583
Hi, I got the same issue, make sure that there isn't a space the end of the key, that solved it for me
jinx100
You will always get the full, correct beta key if you use the "Select all" link in the Code box before copying.
Finn-Again
Thank you all! I used the right key but it might've been the spacing. The "Select All" button advice really helped a lot, still thank you all
I hope me goofing at this helps more peeps like me.
Guillate
The key works on windows, but not on linux ( I'm using ubuntu )
With the command:
I get the error:
version : MakeMKV v1.18.1 linux(x64-release) started
Thank you.
With the command:
makemkvcon reg <key>Code: Select all
Key not found or invalidThank you.
Tasq1
Where exactly are we supposed to enter this key? I've tried pasting it into the registration field. But all I ever get is "invalid" as the result. Program closes after that. I can use Handbrake to rip DVDs, but I'd strongly prefer to use MakeMKV. Will the paid version work? Or does it have problems too?
16442496
Open terminal and copy/paste:Guillate wrote: Sat Sep 06, 2025 10:49 am The key works on windows, but not on linux ( I'm using ubuntu )
With the command:I get the error:Code: Select all
makemkvcon reg <key>version : MakeMKV v1.18.1 linux(x64-release) startedCode: Select all
Thank you.
(This adds key to your .MakeMKV/settings.conf file.)
echo 'app_Key = "T-PuNYycrTTHW4QEOfhDrMuJMpojNqmY5CGuESAKXzHvwBvBcXhtsJLj4g6OAXd1zfzk"' >> ~/.MakeMKV/settings.conf
Guillate
It worked! Thank you very much!16442496 wrote: Mon Sep 08, 2025 2:34 pmOpen terminal and copy/paste:Guillate wrote: Sat Sep 06, 2025 10:49 am The key works on windows, but not on linux ( I'm using ubuntu )
Thank you.
